kompre
(kompre)
September 23, 2022, 7:07am
1
I am looking for a wireless sensor that detects its own orientation, so it can recognize when it is upside down. The most likely that fit my needs seems to be a tilt sensor, but I am not finding any that is cheap or doesn’t require assembly (I’m finding single module for Arduino board, but I don’t have the skills required)
The use case is this: the roborock sometimes get stuck between the legs of the kitchen stool because it doesn’t handle well the shape (wide low base with single leg), so I created a new zone called “undertable” to be avoided when the stool are down; I would like to detect when I rise the stool and flip it upside down to rest over the table, so to start an automation that would clean also the undertable zone.
Hellis81
(Hellis81)
September 23, 2022, 7:13am
2
A wireless sensor tag might do it. They work quite well for sensing changes in the angle of doors/windows, and they’re pretty small. Battery life is about half what they claim, though.
https://wirelesstag.net/
finity
September 23, 2022, 1:43pm
4
Are those tags local or cloud?
Cloud. You need a tag manager too ($50).
kompre
(kompre)
September 24, 2022, 11:20am
6
Stiltjack:
Cloud
then it’s no go for me because I would much prefer a local push solution. Also it does not seems to be available in my country. Thanks anyway
Using a Wemos D1 Mini (clone) and the MPU6050 accelerometer/gyroscope sensor in an ESPHome device would work relatively well. The math/trigonometry is the most difficult part in working with the sensor, but I use one for detecting the state/orientation of my garage door: down (vertical), moving (changing), and up (horizontal).
esphome:
platform: ESP8266
board: d1_mini
# WiFi parameters
wifi:
fast_connect: true
power_save_mode: NONE
domain: .local
use_address: garagedoor.local
reboot_timeout: 5min
networks:
ssid: "redacted"
password: "redacted"
# Enable logging
logger:
level: INFO
# Enable Home Assistant API
api:
ota:
globals:
- id: gyro_angle_x
type: float
restore_value: no
- id: gyro_angle_y
type: float
restore_value: no
- id: gyro_angle_z
type: float
restore_value: no
- id: delta_accel_x
type: float
restore_value: no
- id: delta_accel_y
type: float
restore_value: no
- id: delta_accel_z
type: float
restore_value: no
- id: delta_gyro_x
type: float
restore_value: no
- id: delta_gyro_y
type: float
restore_value: no
- id: delta_gyro_z
type: float
restore_value: no
i2c:
sda: D3
scl: D4
scan: True
- platform: mpu6050
update_interval: 5.00s
address: 0x68
accel_x:
accuracy_decimals: 1
name: "Garagedoor Accel X"
internal: false
filters:
- lambda: |-
id(delta_accel_x) = fabsf(id(garagedoor_accel_x).state - x);
return(x);
accel_y:
name: "Garagedoor Accel Y"
internal: false
filters:
- lambda: |-
id(delta_accel_y) = fabsf(id(garagedoor_accel_y).state - x);
return(x);
accel_z:
name: "Garagedoor Accel Z"
internal: false
filters:
- lambda: |-
id(delta_accel_z) = fabsf(id(garagedoor_accel_z).state - x);
return(x);
gyro_x:
name: "Garagedoor Gyro X"
internal: false
filters:
- lambda: |-
id(delta_gyro_x) = fabsf(id(garagedoor_gyro_x).state - x);
return(x);
gyro_y:
name: "Garagedoor Gyro Y"
internal: false
filters:
- lambda: |-
id(delta_gyro_y) = fabsf(id(garagedoor_gyro_y).state - x);
return(x);
gyro_z:
name: "Garagedoor Gyro Z"
internal: false
filters:
- lambda: |-
id(delta_gyro_z) = fabsf(id(garagedoor_gyro_z).state - x);
return(x);
name: Garagedoor X Angle
update_interval: 5s
internal: false
filters:
- sliding_window_moving_average:
window_size: 5
send_every: 10
send_first_at: 10
lambda: |-
* Convert gyro values to degrees/second
double FS_SEL = 131.000;
double gyro_x_value = id(garagedoor_gyro_x).state / FS_SEL;
double gyro_y_value = id(garagedoor_gyro_y).state / FS_SEL;
double gyro_z_value = id(garagedoor_gyro_z).state / FS_SEL;
* Obtain raw acceleration values
double accel_x = id(garagedoor_accel_x).state;
double accel_y = id(garagedoor_accel_y).state;
double accel_z = id(garagedoor_accel_z).state;
* Calculate angle values from accelerometer
// double accel_angle_x = abs(atan( accel_y/sqrt(pow(accel_x,2) + pow(accel_z,2))) * RAD_TO_DEG);
// double accel_angle_y = abs(atan(-1 * accel_x/sqrt(pow(accel_y,2) + pow(accel_z,2))) * RAD_TO_DEG);
double accel_angle_x = abs(atan2(accel_y, accel_z) * RAD_TO_DEG);
* Round to nearest 0 or 5
id(gyro_angle_x) = round(accel_angle_x / 5.0) * 5;
return id(gyro_angle_x);
binary_sensor:
device_class: vibration
name: "Garagedoor Vibration"
lambda: |-
if (isnan(id(delta_accel_x)) or
isnan(id(delta_accel_y)) or
isnan(id(delta_accel_z)) or
isnan(id(delta_gyro_x)) or
isnan(id(delta_gyro_y)) or
isnan(id(delta_gyro_z)))
id(garagedoor).publish_state("Idle");
return {};
else if (abs(id(delta_accel_x)) > 1.0 or abs(id(delta_accel_y)) > 1.0 or abs(id(delta_accel_z)) > 1.0)
return(true);
} else {
return(false);
filters:
on_press:
then:
- text_sensor.template.publish:
state: Moving
on_release:
then:
state: Idle
device_class: door
lambda: |-
id(garagedoor_open).publish_state("????");
return {};
else if (id(gyro_angle_x) > 87 && id(gyro_angle_x) < 93)
id(garagedoor_open).publish_state("Closed");
return(false);
} else {
id(garagedoor_open).publish_state("Open");
return(true);
filters:
on_press:
then:
state: Open
on_release:
then:
state: Closed
text_sensor:
icon: mdi:garage-variant
update_interval: 5s
update_interval: 5s
Hellis81
(Hellis81)
September 25, 2022, 7:45pm
8
But you can’t have ESP-home on a battery powered device.
kompre
(kompre)
October 1, 2022, 1:59pm
10
I went with your suggestion and get my hand on an aqara vibration sensor.
I have it paired to a sonoff zigbee 3.0 dongle plus and works like a charm. I didn’t even had to install any aqara or sonoff app, no need to create the n-th account for a service that I would have used once. Local solutions are so nice!
