You can use notification integration and install Automate app, have the app watch for companion app notification and what’s written in it (title) then have automate app react on whatever notification title you’ve sent. U can lock unlock and do whatever you want inside automate app. In HA make an automation that sends a notification and have a helper toggle or a button to have a toggle or button to activate that automation or a sensors
as activator. Hope I’m making sense here
PS Have the automate app in a loop, if notification title is this do that and clear notification , if no notification wait for it.
To clear notifications install this App and have automate open it when u want to clear notification ( app just opens and clears notifications and closes on its own)
From what I’ve read there is local push for both iOS and Android. But if you aren’t able to get that to work you can always go with telegram integration to notify
is this really the final solution and best practice we should work with? It feels more like a workaround.
There has been the adb addon, but it is deprecated. Why is no proper successor introduced?
Companion is not (yet?) filling the gap. Is it planned to do so for the future?
I stumbled upon the same issue as the thread creator unable to find a fitting solution.
thanks,
best regards
Markus
So here is my feedback…
I would still prefer the method to just send an adb command to turn on and off the screen.
I tried using full kiosk browser / app but 9 out of 10 times it’s stuck at “initialing” at the Homeassistant page… apparently it’s a known issue, so no luck there…
I’m using Android TV integration for an android tablet hanging on the wall to turn on/off screen. It supports natively this function. As far as I know via this integration you also able to send custom adb commands to the device
