SEAT Connect car integration in Hassio
Thanks.
The addon part is sufficiently mature and probably won’t need much more in the short term. The Edge build offers the latest alpha releases, and the normal build will integrate them as soon as validation is complete.
But carconnectivity is still evolving. Lots of other little features on cars need to be integrated to be exploited by HA. So if you’ve got the skills, or the time, all help is welcome.
Unfortunately I’m not getting any data, what am I doing wrong?
Try restart the addon and if still ko, then open an issue and provide details
Can you explain how you did it? When do you need to configure Mosquitto MQTT?
Hi @tony77682 ,
after Installation of the Add-On, on its ‘Configuration’-tab, I filled in my login credentials of my Mosquitto broker-Add-On, that I had up and running from a previous project. How to setup MQTT for Home Assistant, can be found on youtube.
Short after startup of the ‘CarConnectivity Addon’, in my MQTT-Integration appeared the coresponding vehicles as a mqtt-device.
I also had the behavior of the ‘CarConnectivity Addon’ that some values were filled with values, after they had been altered (e.g. Position of my Seat Mii).
thanks, I just managed to configure with mqtt
The addon works great. But If i start for example some Action Like start charging, i get No Response of that value until the addon refreshes the values in his usual time configured, for example 600 Seconds (10 Minuten). The myseat App ist crap, but it sends a notification after If that Action was successfully and that would be a great Feature.
That’s not a bad idea, but it’s has to be done with care as api is quota restricted.
You can create an issue for feature here: GitHub - tillsteinbach/CarConnectivity: Python API to retrieve telemetry data from various car brands
For exemple force refresh to 60s after start charging (or start climate)
Issue already exists
