I need to extend Zwave into a shop. Today I have HA running on unraid, everything running in seperate dockers, including Zwave js at my house. I’ve already tried using outside Zwave devices as a repeater to get my Zwave network extended to the other building unsuccessfully.
I have a second ZooZ 800 series Zwave controller, but I need to plug it into something at the second building and then I will run a second instance of Zwave js for that location. Is there something that will work with this controller to make it network attached, or do I need something like a HomeSeer Z-NET G3 which appears to do what I want ?
From a network perspective, the actual network is already available between the two buildings.
