How does motion sensor should react on automation?
I thought after an motion is detected and the automation is triggered, it should be triggered again after another motion is registered? Is this the outcome I should be expecting?
If this is the case, they don’t “retrigger” when detected new movement after the first movement is registered. Hopefully you understand what I meant. Any ideas?
Screenshot is as follows. Sensor is Tuya PIR with ZHA.
I would have to see the YAML of the automation.
Go to “Developers Tools”, States, and filter on your entity.
Have someone walk near the sensor and notice what the state of the entity is. Also, how long after they leave the vicinity of the sensor does the state change again?
