Hi. I run HAOS on an Odroid N2+
It is connected to my home network via the built-in network adapter.
To be able to connect with devices on the community network, I added a USB network adapter and gave it a fixed IP and ipv4 route in nmcli.
This worked for a while, but it doesn’t anymore.
In the Network setting of the HAOS GUI, I can see two network interfaces:
END0 is the built-in network adapter. I have no idea what ENU1U3 is.
However, if I look in nmcli, I can see multiple interfaces:
➜ ~ nmcli connection show
Warning: nmcli (1.44.4) and NetworkManager (1.44.2) versions dont match. Restarting NetworkManager is advised.
NAME UUID TYPE DEVICE
Supervisor eth0 b1ee0c50-f24e-311e-b00a-c248f24cf368 ethernet end0
lo e996f956-8ad0-4d31-84d7-42eb346fe64d loopback lo
Supervisor eth0 1fa29816-9dd1-43f1-9cf2-facc36901be6 ethernet --
Supervisor eth1 5659b9fc-a093-364b-a48f-4d5086a7d618 ethernet --
The lower two both seem to have my manual settings.
What’s the cause for this and how do I fix it?
(My setup is completely up-to-date)
