I’m building a temp sensor for each room with an esp8266 & a DS18B20 temp sensor. I was able to build the first one without any trouble using esphome and it was discovered by HA. When I built the second sensor, I followed the same process and its showing in esphome but HA won’t recognize it.
I can fetch logs from the first sensor via WiFi and it displays the expected temps. I can also fetch logs from the second sensor via USB (its still connected to the computer Pi4 for debugging) and it displays the expected temps.
The second sensor isn’t recognized by HA and I can’t add it to the esp home integration - its shows an error:
Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.
I’ve tried with both the mDNS entry and well as the IP. Neither works but I can ping both from my MacBook so I know the sensor is on WiFi.
When I gather logs from the second sensor via WiFi I get an error:
INFO ESPHome 2023.10.3
INFO Reading configuration /config/esphome/pipers-room.yaml…
INFO Starting log output from pipers-room.local using esphome API
WARNING Can’t connect to ESPHome API for pipers-room.local: Error connecting to (‘192.168.86.63’, 6053): [Errno 111] Connect call failed (‘192.168.86.63’, 6053) (SocketAPIError)
INFO Trying to connect to pipers-room.local in the background
Working yaml file:
esphome:
friendly_name: Living Room
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "<Top Secret Key>"
ota:
password: "<Password>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Living-Room Fallback Hotspot"
captive_portal:
dallas:
- pin: D2
- platform: dallas
address: <Address>
- platform: dallas
address: <Address>
Broken yaml file:
esphome:
friendly_name: Piper's Room
esp8266:
board: nodemcuv2
# Enable logging
logger:
api:
encryption:
ota:
wifi:
ap:
ssid: "Pipers-Room Fallback Hotspot"
captive_portal:
dallas:
- pin: D2
- platform: dallas
address: <Address>
- platform: dallas
address: <Address>
