I have had a sonoff running for ages with the code from misperry
but when adding a second one they seem to be intefering with each other. Only one will work at a time even though there sub/pub details are different. They both appear connected but when one is responding to on/off commands the other does nothing and vica/versa. They swap over every couple of minutes.
Has anyone else had anything similar?
Code for 1st sonoff:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "xxx";
const char* password = "xxx";
const char* mqtt_server = "192.168.1.6";
#define mqtt_user "username" //enter your MQTT username
#define mqtt_password "password" //enter your password
WiFiClient espClient;
PubSubClient client(espClient);
int SwitchedPin = 12, LEDPin = 13, Override = 14, OverrideMem = 0;
bool HassSwitch = false;
String switch1;
String strTopic;
String strPayload;
void setup_wifi() {
Serial.begin(115200);
delay(2000);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
pinMode(LEDPin,OUTPUT);
digitalWrite(LEDPin, HIGH);
void callback(char* topic, byte* payload, unsigned int length) {
payload[length] = '\0';
strTopic = String((char*)topic);
if(strTopic == "kitchen/led1") //xxxxxxxxxxxxxxxxxxxxxxxxxxxxx match with yaml xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
switch1 = String((char*)payload);
if(switch1 == "ON")
Serial.println("ON");
digitalWrite(SwitchedPin, HIGH);
digitalWrite(LEDPin, LOW);
HassSwitch = true;
else
Serial.println("OFF");
digitalWrite(SwitchedPin, LOW);
HassSwitch = false;
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("arduinoClient", mqtt_user, mqtt_password)) {
Serial.println("connected");
// Once connected, publish an announcement...
client.subscribe("kitchen/led1"); //xxxxxxxxxxxxxxxxxxxxxxxxxxxxx match with yaml xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup()
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(SwitchedPin, OUTPUT);
void loop()
if (!client.connected()) {
reconnect();
if(digitalRead(Override) != OverrideMem && !HassSwitch)
if(digitalRead(Override))
OverrideMem = 1;
else
OverrideMem = 0;
client.loop();
code for second sonoff:
const char* password = "xxxx";
String switch1;
String strTopic;
String strPayload;
void setup_wifi()
delay(2000);
Serial.println();
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
if(strTopic == "bathroom/glass1") //xxxxxxxxxxxxxxxxxxxxxxxxxxxxx match with yaml xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
if(switch1 == "ON")
HassSwitch = true;
else
HassSwitch = false;
void reconnect() {
client.subscribe("bathroom/glass1"); //xxxxxxxxxxxxxxxxxxxxxxxxxxxxx match with yaml xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
else {
delay(5000);
void setup()
setup_wifi();
void loop()
reconnect();
OverrideMem = 1;
else
OverrideMem = 0;
client.loop();
yaml entries:
switch 9:
platform: mqtt
state_topic: “kitchen/led1”
command_topic: “kitchen/led1”
qos: 0
payload_on: “ON”
payload_off: “OFF”
optimistic:
false retain: trueswitch 10:
platform: mqtt
state_topic: “bathroom/glass1”
command_topic: “bathroom/glass1”
qos: 0
payload_on: “ON”
payload_off: “OFF”
optimistic:
false retain: true
