Hi. I have a problem with my ISP’s router: it reboots several times a day, usually in the hottest hours of the day, but sometimes also at night.
I don’t want to change ISP because it’s the only one to offer optical fiber from home, in my city, but unfortunately I’m forced to use their router. I’ve read several people complaining about the reboots, and already tried to cool the router with the most powerful fan I have found of compatible size, but with no luck (5/10° less then before, still rebooting apparently at random).
I have a 4G backup connection for my PC, but my “smart” devices go offline for about 5 minutes at every reboot, while the WiFi is available again.
Last week I made my first installation of Hassio on an RPi3 with Conbee2, and I already fell in love with it. Now I can control various devices from their native clouds and also from HA (but I’ll take the “next step”, detaching from clouds, as soon as i’ve time to reconfigure everything) and I still have the reboot problem: as static ips are assigned by the router, HA goes offline with it too.
The ideal solution for me would be to have a device that provides a WiFi LAN while the router is rebooting, and assigns the same IP addresses (I could scrape IPs and MACs daily from the router’s web interface to keep it updated, but it’s http so… not sure, maybe i’ll just set them manually on each “router”).
I’ld prefer not to always have a DHCP server and routing tables not the main router, to keep latency down: speed is a concern, and when the router is powered it’s great.
If this secondary device could also use the 4G hotspot to provide a backup LAN with internet, that would be great, as I could still connect to HA via WireGuard when not at home. But i’ve not figured out how to implement it yet.
I’d already be equipped to create a fake access point of my own WiFi, but I don’t know if it’s a good idea.
Another solution I thought of is to permanently separate hassio-connected devices from the rest of the LAN, via a dedicated subnet or WiFi. So the secondary router (not necessarily a “router”: it could be another RPi, or the same one in which Hassio runs, or … I don’t know, suggestions are welcome!) would always be active, and it could use 4G too to provide me access to Hassio, whether I’m at home or away, when the main router is down.
Here’s how the two network maps would look like:
Any idea? Thank you so much in advance for the feedbacks, and for all the information this magnificent community has already given me.
