Sitnalta
(Sitnalta)
February 24, 2019, 3:16pm
1
Hi everyone,
Today I did the HASS update to 88.1 and found this error in my log:
Invalid config for [automation]: [seconds] is an invalid option for [automation]. Check: automation->trigger->0->seconds…
Did I miss something about the Time Trigger support in automations?
This is the automation that stopt working:
alias: "HASS Startup Status"
initial_state: true
hide_entity: false
- platform: time
seconds: "/15"
- service: switch.turn_on
entity_id: switch.remote1vijverpomp
entity_id: switch.wandschakelaarvijverpomp
- service: script.turn_on
entity_id: script.dahua_preset_oprit
- service: automation.turn_off
entity_id: automation.HASS_Startup_Status
I need this automation to reset the status om some sensors, after a HASS reboot.
The script must run 15 seconds after HASS startup, the script in the action list will kill the automation.
Any help is appreciated
You’ll have to use the new “time_pattern” trigger. This has changed recently: https://www.home-assistant.io/docs/automation/trigger/
Sitnalta
(Sitnalta)
February 24, 2019, 3:54pm
3
That was a easy fix, thanks
initial_state: true
hide_entity: false
- platform: time_pattern
seconds: "/15"
123
(Taras)
February 24, 2019, 4:10pm
4
If the goal is to run a script 15 seconds after Home Assistant starts, this is a very curious choice of trigger:
seconds: "/15"
The /
in "/15"
means to run every 15 seconds. Here’s the documentation link:
Here’s an example of an action that executing a service 5 seconds after Home Assistant starts:
- alias: 'Start HomeKit'
hide_entity: true
- platform: homeassistant
event: start
- delay: 00:00:05 # Waits 5 sec
- service: homekit.start
If we apply the same technique to your automation we get this:
- alias: "HASS Startup Status"
initial_state: true
hide_entity: false
event: start
- delay: 00:00:15
Sitnalta
(Sitnalta)
February 24, 2019, 4:22pm
5
I had it like that before, but it was not stable, HASS startup did not always trigger.
My automation will only run ones when it is triggered, because in the actions there is a script that disabled the automation.
123
(Taras)
February 24, 2019, 6:01pm
6
Which version of Home Assistant are you using?
If it ‘did not always trigger’ it implies the event was not created or was not recognized by the automation’s trigger. Either way, that would be a serious bug.
For reference, I’m using 0.80 and the `Start HomeKit’ automation I posted above. It has always worked.
