Secretlabs MAGRGB LED Light strip by Nanoleaf does not appear in HASS
Hi all!
I’m trying to figure out how to get my level bolt smart lock into my HA and I thought it was the only device I can’t connect.
Then I remembered I have this secretlabs x Nanoleaf led strip that has a thread network and integrates into my HomeKit and even Alexa networks.
However, home assistant doesn’t recognize it (it’s not a mentioned supported device from the Nanoleaf integration) and I’m trying to find other ways to force it in.
I tried connecting a HomeKit bridge controller but it’s not recognized there either which I guess isn’t surprising but I thought perhaps if it’s integrated with HomeKit I can use it to connect to HA (same issue with level lock I guess)
Has anyone has success in connecting a thread network device or more specifically a secretlabs magrgb strip?
Many thanks in advance
I’ll second this, looking for a solution to add this to HA
appreciate that… seems like no one has this in their instance… just a horribly unreliable light… need to redo my automations at least once a quarter or more.
Has anyone found a solution to this? I was able to add my Nanoleaf shapes to HA, but I can’t find a way to get the SecretLabs light strip added.
you have to start the setup in homekit, but before formally adding it to your homekit, it should be recognized in by your home assistant, then you could add it.
So, one big piece of information that would have been useful that I finally found somewhere (sorry, can’t find where) is that this device can only have a single controller. So if you have the app connected to it (currently the only way I know of to do anything other than turn it on/off), you can’t also connect it to HA. And switching controllers resets the light. Until more RE has been done to support it more, I don’t think there’s a good solution to this.
On the fence about buying this for my Secretlab Magnus Pro, has anyone had success with this?
It looks like you can set this light up in Apple Home. Following that, can we not just use the HomeKit Device integration?
I have it, and it works okay now. It’s a bit delayed when responding to commands/automations in HASS and doesn’t have any of the cool presets, but you can leave your favorite preset on and just use the on/off function in HASS.
Yes, you can use it through the apple home kit bridge, or (what I did) was load it into apple home, but instead of continuing with setup in apple home, it appears as a new device in HASS. Just follow the steps on screen.
Was anyone able to get the device paired to both the Nanoleaf app (to set cool effects) and to Home Assistant? I was able to pair to Home Assistant, but the Nanoleaf app is telling me to reset the device to continue pairing.
I’m out here still looking for any help on this device.
Part of why it seems so confusing is it’s a Thread/HomeKit/Matter device it seems. I’m very familiar with wifi-based devices, as well as Zwave and Zigbee. With that said, what a baffling standard. It’s wifi, but not? It’s bluetooth it seems to connect this light strip to my phone, but I can’t get anything else to work with it. I know there are thread and matter integrations for Home Assistant, but they both seem to require a border router for the standard. Again, great! More USB fobs to buy for my RP-based Home Assistant server. My gut tells me there’s GOT to be a way to simply use bluetooth, which my HA server has already. Can anyone at least unmuddle the mess that is Thread/Matter/Homekit for us?
I got it to integrate using the homekit for apple. Once it’s in pairing mode, it pops up in HASS, continue on hass, ignore the phone.
No cool effects, just static colors. I leave it set to that rainbow effect, and just use the on off feature, which works.
Just learned this today after a ZBT-1 came in and I configured it as a border router for Matter. Still couldn’t get it to pair via Matter, then found the Apple Homekit device option and it worked like a charm.
