Secrets.yaml hiearchy
I have some secrets that should be grouped so instead of
somelongname_client_password: xxx
somglongname_client_key: yyy
I would like to setup the secrets file as:
somelongname:
  client_key: yyy
which would also make it clearer what secrets belonged to.
I did try !secret somelongname.client_password but this doesn’t work.
So does secrets.yaml have to be flat with all entries at the root level?
Yes it has to be a flat file.
You can add comments to make it clearer.
##some long name details
sln_client_password: xxx
sln_client_key: yyy
With most details like this now being provided through the UI rather than the config your secrets file won’t contain as many secrets as you’d expect
