Tried setting up secrets.yaml but receive error message…
homeassistant.loader: Unable to find component secrets
My configuration file includes…
secrets: !include secrets.yaml
http:
api_password: !secret http_password
And the secrets.yaml is formatted as per the instructions…
debug: 0
http_password: [Redacted]
Has anyone else got this working?
Edit: I am running hass 0.23 docker container on a synology, with no other errors
Edit 2: just tried changing my http_password and it does actually work, but the error still occurs.
Will try adding some more secrets
Yes, I have just tried to add a secret from a config file nested within a folder (/config/misc) & hass would not restart with error…
secret not defined
Obviously there is still a bit of work to be done on this feature, but it will be excellent when it’s fixed
Cheers
You don’t need a definition to the secrets file in your configuration file. Try commenting it out and restarting.
fabaff
(Fabian Affolter)
5
secrets is not a component. Just create the secrets.yaml file.
ah-ha! i have deleted that line & it removes the error
Cheers
SirBerg
(Tobias Berg)
7
I have the same problem but I am not understanding the solution.
My configuration.yaml
My secrets.yaml
http_password: ‘apassword’
Error message:
Invalid config
The following components and platforms could not be set up:
Please check your config.
But the site is asking for my password and are working. Damn enoying though having this message showing!
Completely remove the line
jatgm1
(jatgm1)
10
so is it just assumed by the system that secrets.yaml exists? you dont need to tell home assistant?
There is no secret: component.
!secret is a homeassistant keyword that means ‘replace this with the corresponding entry from secrets.yaml’.
