I am running hass.io 0.102
I had everything working with all the info in configuration.yaml
, but decided to break out my secrets into secrets.yaml
. But things aren’t working as expected.
my secrets.yaml
file looks like this:
# zwave
zwave_network_key: X
# Pushover
pushover_api_key: X
pushover_user_key: X
# Nest
nest_id: X
nest_secret: X
# Lutron
lutron_ip: X
lutron_mac: X
The relevant portions of my config.yaml
file are
# Z Wave
zwave:
usb_path: /dev/ttyACM0
network_key: secret! zwave_network_key
# Nest
nest:
client_id: secret! nest_id
client_secret: secret! nest_secret
# Lutron caseta
lutron_caseta_pro:
bridges:
- host: secret! lutron_host
mac: secret! lutron_mac
notify:
- name: pushover
platform: pushover
api_key: secret! pushover_api_key
user_key: secret! pushover_user_key
I’ve swapped out the secret! secretname
version for the actual data for each one individually. Each time, I check the config before restarting and it checks out fine, but here’s what happens:
- Z Wave: homeassistant doesn’t load
- Pushover: homeassistant loads, but notifications aren’t sent
- Nest: everything works fine
- Lutron: I have to re-run the integration report, and when I do, it pulls in all the IDs for my dimmers, but I can’t control them. This one is the most understandable because I’m using a plugin that’s not merged into homeassistant yet, and all the files live in a subfolder - not sure if that makes a difference.
Does anyone have thoughts on how to fix this?
