Love the new Sections layout over the problems with Masonry!
I think vertical spacing between cards is OK, but why is that not the same to the horizontal spazing?
Masonary:
Sections:
Can this be adjusted?
Thanks,
Ase
Masonary:
Sections:
Thanks,
Ase
I think you made 2 sections next to eachother. You can also put the cards into one section (and maybe make the section wider if you wish.
In this picture I have 2 sections on the left which has a bigger spacing inbetween and on the right all cards in one section with equal spacing between cards.
Edit mode:
To be able to fit more light cards next to eachother you need to change the width in the Layout tab. There change the marked slider from the default 4 thingies to 2 thingies.
Thanks a lot Michel!
All this I did not know!
This solved my case!
Setting card to:
and section to:
Nice that I can now fit 6 light cards in the same row on my PC:
But on my iPad it did go from 3 cards on the same row (masonary) to only 2 cards now, can that be controlled?
//Ase
I don’t know how the arranging/resizing works so not sure if/how it can be controlled.
