@mgejke I just tried to run the Sector app on my phone at it could not get status from my central at home so I quickly gathered that this was not a HA issue but an issue with the alarm system itself. When I called Sector I complained about their app, no info about HA at all Good secrets are best kept well hidden imho
The stated that my central was āofflineā. Whatever that means. The central is GSM based. What they did I do not know but suddenly it worked again. The probably booted it or something similar.
Mains and mainsrestore might be if the central looses power from the mains in the house. I know that the system puts out alarms on both loosing power, low battery on devices and more. This data is relayed to Sector and not to the user/app or similar. Not sure if the log entries you see could be related?
I have tried this too and it works! I have been looking for this functionality a long time, thanks!
However, I can confirm that asyncsector folder needs to be in custom_components on a hass.io install.
One questions though:
How do I show the attributes last_changed and changed_by in the UI?
I have added the following to my customize.yaml, but nothing shows.
Havenāt actually tried hass.io, I just assumed it would resolve dependencies like a plain HA-install would, but if you say asyncsector-folder is needed Iāll trust you
There is no last_changed attribute on the alarm component. Where did you get that from? I guess it could be addedā¦
Must admit that Iām a bit new to this but appreciate if any help can be provided.
Iāve added the components according to @endor instructions but get the following error:
Error during setup of component sector_alarm
File ā/usr/lib/python3.6/site-packages/homeassistant/setup.pyā, line 190, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File ā/config/custom_components/sector_alarm.pyā, line 83, in async_setup
CONF_CODE: config[DOMAIN][CONF_CODE]
KeyError: ācodeā
Iām running Hassio, 0.60.1 and added asyncsector to the custom_components folder as well.
Hmm yes, that is strange.
You could enter 0000 as code if you donāt plan to use homeassistant for arming or disarming your alarm, that way you will never expose your pin in a text file.
Hi!
Would be very very nice! ā¦If only I could get it to work.
No AlarmPanel on first page. No Entities under states-page. Only visible i could find is āSector Alarm 1234567ā under History with status āunkownā. Zero errors in home-assistant.log
Running Hass.io 0.60 and since today 0.60.1.
Have been following endorās instructions.
Thanks for a great component, I have been looking a long time for a way to integrate Sector Alarm into HA!
Would it also be possible to add door sensors?
I donāt think so, from what Iāve seen thereās no information about the door sensors on their homepage(might have changed). And anyhow, since it keeps up with Sector Alarm by polling, it might as well miss that a door was open(unless thereās some kind of history).
Iām new to HASS and decided to go the hass.io way. However I canāt get this to work. The home-assistant.log has some entries: https://pastebin.com/amLWm7xd
