Sector Alarm
You are right it start with a zero, will try as soon as I come home. Keep you posted.
Thanks!
@donjohann
Yes so I actually resolved this problem past weekend. The problem was just what you wrote @mgejke. When using ā€˜ā€™ around the alarm_id, code, email and password the problem was resolved.
sector_alarm:
  email: '[email protected]'
  password: '12345678'
  alarm_id: '12345678'
  code: '00000'
Something else that is weird is when using thermometers: or thermometers: true. The thermometers donā€™t show up. When removing this line all together they show upā€¦
What is the alarm_panel-line supposed to do?
When I turned on the logging in HASS.io I got the same error you did about the temperatures. Use ā€˜ā€™ around your alarm_id and code. Check my previous post from today.
I am no python coder but it seems to fail when it thinks the value is an integer and not a string.
It fails to connect to Sector Alarm but still tries to get the thermometers.
@Jesperj
Thatā€™s correct, it will log in succesfully, but fail when trying to request anything using the alarm_id since itā€™s incorrect.
Iā€™ll check what it says when you do that and try to give a better errorā€¦
the alarm_panel-line is just if you for some reason only want the temperaturesā€¦ :slight_smile:
It works @mgejke @Jesperj !
Added ā€œā€ for email, password, alarm_id and code and I got the thermometers to work. Nice.
Next action, make logic on the alarm entities :smile:
Thanks for the support!
Hi, I just got a call from Sector Alarm, they say my central is contacting their central way more often that it should. Is there a polling thing in the code somewhere that can be extended?
Or any other tips.
@Bjorn_Hegle
Interesting! What did you say to them? Howā€™s your central connected?
Thereā€™s a flag called scan_interval for polling components i HA, try setting it to something bigger. Iā€™m not sure if it works out of the box or if I have to do something in the components as well.
scan_interval: <seconds>
Try that, if it doesnā€™t work Iā€™ll add a setting for itā€¦
Finally fixed it. Had some problems with dependencies, but after an reinstallation of home-assistant and using ā€™ I got it working.
Thanks for all the help.
Was that a problem for them? And what did they say about it?
Did you mention your setup?
They asked me if I used the app in a special way or something. I didnā€™t tell them about the hassio setup :stuck_out_tongue:
My central is connected directly to my router.
They are coming on Tuesday to swap out my central, so Iā€™ll see after that if it was the central or this component.
Hi
I have updated my Home Assistant (Home Assistant
0.65.4) and now I got this error:
- Invalid config for [sector_alarm]: required key not provided @ data['platform']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sector_alarm/
Still working though, but quite annoying with the error showing up.
Config is like this:
sector_alarm:
email: ā€˜[email protected]ā€™
password: ā€˜XXXā€™
alarm_id: ā€˜01234567ā€™
code: ā€˜0000ā€™
thermometers: true
alarm_panel: true
Has this been integrated into HA? I found this on Github:
Hi
I have exactly the same error on version 0.65.5 and same config as ā€œdonjohannā€ except for the last two parameters, they have # before the parameter.
The component have stopped working!
Anyone found a solution?
@patrikfrisk, @donjohann
Ah, I havenā€™t upgraded HA in quite a while. Iā€™ll try to do that and see if I can fix the problem(hopefully this week)ā€¦
Hi
I just want to confirm that I have the same problem that the component have stopped working. I also have 65.5 installed.
@Jesperj, @patrikfrisk, @donjohann
Running 0.65.5 on a raspberry pi with the latest code from https://github.com/mgejke/hass-sectoralarm I donā€™t get any errors at all.
Could you give me some more info?
Iā€™m also running on a raspberry pi and I have tried to replace the sector-alarm code again from
This is my config in configuration.yaml
sector_alarm:
  email: "[email protected]"
  password: "my secret password"
  alarm_id: "my alarmid"
  code: "0000"
  #thermometers: false
  #alarm_panel: true
But I still recive the following error:
Failed config
sector_alarm:
- Invalid config for [sector_alarm]: required key not provided @ data[ā€˜platformā€™]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sector_alarm/
I canā€™t reproduce the issueā€¦
From googling the error message it seems that it might be related to formatting, tabs/spaces etc.
Is your config split in different files? Could anyone post more or the entire config(as a code snippet so the formatting is correct)?
This i my Configuration.yaml with the formatting included.
The Sector_alarm component is found in the bottom of the configuration.yaml
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: xx.xxxxxxxx
  longitude: yy.yyyyyy
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 39
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Stockholm
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: Welcome
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
# cloud:
# Pushbullet
notify:
  - name: Pushbullet
    platform: pushbullet
    api_key: My APIkey
# Devices
device_tracker:
  - platform: ping
    interval_seconds: 30
    consider_home: 1200
    hosts:
      Patrik_iphone: MyIPAddress
      Hugo_samsung: MyIPAddress
      Malin_iphone: MyIPAddress
# Sector Alarm
sector_alarm:
  password: "My Password"
  alarm_id: "My AlarmID"
  code: "0000"
  #alarm_panel: true
# Includes
group: !include groups.yaml
script: !include scripts.yaml
I receive the same error message if i restart homeassistant.
If i do a full host reboot of hassio it works without the errorā€¦
