The code now works for the latest Home Assistant.
Hmm
82.1?
I still get this error:
Error during setup of component sector_alarm
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
hass, processed_config)
File "/config/custom_components/sector_alarm.py", line 82, in async_setup
CONF_CODE: config[DOMAIN][CONF_CODE]
TypeError: load_platform() missing 1 required positional argument: 'hass_config'
Have you pulled the latest code from github?
Yeah!
Sorry, no I hadnât, but now I have and that did work very well. Thanks!
This seems really interesting, but I think I must be doing something wrong. I keep getting the following error every minute. Iâve tried to read the source code on https://github.com/mgejke/hass-sectoralarm/blob/master/sector_alarm.py, but canât seem to figure out what is causing the problem. It might be the login, but a login error is supposed to throw a different message, so Iâm guessing I managed to log in correctly. Does anyone have an idea as to what I might be doing wrong?
Sector Alarm failed previous update, trying to login again
I have a problem with disarming through automations. The log says " Invalid code given".
I am sure I use the right code. It is possible to disarm the alarm through the frontend with the given code. I have tried formating the code in different ways with no success.
code: 0000
code: â0000â
code: â0000â
Non of the above works. I want to disarm the alarm when my vacuum robot is vacuuming the house.
Anyone else got a call from Sector Alarm when using this component? If you did/did not did you have the thermometers on or off? Donât want to enable it if I am just going to get a call saying I am overloading their API
Hello, I still have to power off my Hass.IO to get this component to work. If I restart in software it fails. Is this a problem everyone has or only me? I thought this was solved in a git-release but I am running latest versions of everything and still it foobarsâŚ
I have not had any calls but not using thermometer either
Just installed on a new Hass.IO setup and I still get errors if I do not power it off properly. In the log I only find this:
2019-01-08 08:19:58 ERROR (MainThread) [homeassistant.setup] Setup failed for sector_alarm: Component failed to initialize.
Have tried my config with ââ and ââ and with no quotes, stille the same. My alert panel shows the following:
Config:
Sector Alarm
sector_alarm:
email: !secret sector_username
password: !secret sector_password
alarm_id: !secret sector_alarm_idcode: !secret sector_code
thermometers: false
alarm_panel: true
Secret:
sector_username: '[email protected]' sector_password: 'password' sector_alarm_id: '0123456' sector_code: '123456'
Alarm Panel (ui-lovelace.yaml):
- icon: mdi:shield title: Alarm cards: - type: alarm-panel entity: alarm_control_panel.svingensvingen_alarm
This problem should be solved in the files available on github.
When you update the files in custom components folder, make sure to download the latest version from the git repository and update all files. There are files in subfolders as well (like sensors/ etc).
I think this particular fix is in the main file custom components/sector_alarm.py
If you find the line ending with
âŚimport PLATFORM_SCHEMA
That is the cause for error and you need to update the files or simply remove this line
Thank you @endor for your reply!
I have a copy of all my config here: https://github.com/corvy/home-hassio and I cannot find the âPLATFORM_SCHEMAâ in any file in my custom_components subdirs. If you could have a look I would be very happy!
And just to be perfectly clear I just installed all fresh from git just two days ago due to a total data loss on my old solution. So there should be no old config or datafiles lingering.
The configuration.yaml looks correct. and if it works on reboot it should not be any content issues.
I have also secrets in use. All secrets regardless of format are in double qoutes in the secrets file.
sector_code: â0000â
Only difference from your config is that i have thermometers: true
and my code is defined as opposed to yours is commented out⌠although with dummy code in secrets.
Ok I changed to your setup:
And I double quoted all settings in secrets, also I used a dummy code. Still the same error⌠I will do a hard reboot at home and then test a reload aftewards to see if anything has helped but it seems notâŚ
Nah, still fails even with hard boot. Not sure what is wrong. Not sure I have a verified test since I reinstalled. Any way to turn on debugging of the component? The logs give me nada as-is.
Just got an email from Sector that they have locked my account Seems they have gotten some error on logins. When I unlocked it now it all works!
My sector_alarm seems to work about every other restart in hass.io. When it fails, I get this in the log:
2019-01-15 16:06:46 WARNING (MainThread) [homeassistant.setup] Setup of sector_alarm is taking over 10 seconds.
2019-01-15 16:06:47 ERROR (MainThread) [homeassistant.setup] Error during setup of component sector_alarm
File "/config/deps/lib/python3.6/site-packages/asyncsector/asyncsector.py", line 36, in login
AsyncSector.Base + AsyncSector.Login, json=self._auth)
File "/usr/local/lib/python3.6/site-packages/aiohttp/client.py", line 424, in _request
await resp.start(conn)
File "/usr/local/lib/python3.6/site-packages/aiohttp/client_reqrep.py", line 818, in start
message, payload = await self._protocol.read() # type: ignore # noqa
File "/usr/local/lib/python3.6/site-packages/aiohttp/streams.py", line 566, in read
await self._waiter
concurrent.futures._base.CancelledError
File "/config/custom_components/sector_alarm.py", line 58, in async_setup
if not await async_sector.login():
File "/config/deps/lib/python3.6/site-packages/asyncsector/asyncsector.py", line 42, in login
return True
File "/usr/local/lib/python3.6/site-packages/async_timeout/__init__.py", line 45, in __exit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.6/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
Iâm using this custom component and itâs working almost flawlessly, I have the random âcanât start sectorâ but a restart normally sorts it out. So thank you!
Now on to my question,
Iâm been trying to find out if there is a way to add triggering the alarm.
From reading through the code it seems that the component only supports arm_home, arm_away, disarm
On my Swedish sector alarm I have 2 âtrigger typesâ
- âtrygghetslarmâ or âpanic modeâ basically a mode for when your not feeling safe . say someone is trying to break in during the night.
- the basic alarm trigger. from a motion sensor or door sensor etc.
But, neither of these modes are possible to trigger via the app or webpage.
Does anyone know if itâs exposed through commands even though you cant see it in the app or on the homepage?
Have anyone researched this?
So, after 0.88.1 upgrade sector broke for me.
It times out when starting, similar to @tomoqv error message.
- In file
\config\deps\lib\python3.7\site-packages\asyncsector\asyncsector.py
Removed the linesimport async_timeout
andwith async_timeout.timeout(10):
(+ changed indentation of following 7 lines)
Copy of my file is here: https://pastebin.com/YrmgukQX
Not sure if it is due to that my sd-card is slow or why it times out, but removing the timeout completely works in my setup, verify if it works for you and then we can propose to have it removed as default in git and the module?
- Rearranged files in custom components
create new folder
custom_components\sector_alarm
Move
custom_components\sector_alarm.py
tocustom_components\sector_alarm\__init__.py
Move
custom_components\sensor\sector_alarm.py
tocustom_components\sector_alarm\sensor.py
Move
custom_components\alarm_control_panel\sector_alarm.py
tocustom_components\sector_alarm\alarm_control_panel.py
This seems to be the new expected folder structure that aligns with this change:
