Already for several days I have been struggling with setting up (encrypted) external access to Home Assistant without success.
I have registered a domain name, and I would like to use a subdomain (A-record) to forward a request to my own external ip-address.
On HomeAssistant, Nginx Proxy Manger is installed and it is possible to establish a non-secure connection (by using http://subdomain.nl). Therefore, on the router, http port80 is forwarded to the internal ip-address of HomeAssistant.
Of course it is recommendable to use a secure connection and a Let’s Encrypt certificate. Normally, on the router port 443 could be opened to forward traffic to the internal ip-address of Home Assistant. However, this port is already used for my NAS. Whatever I do (including alternative https-ports 4443 or 8443), by typing https://subdomain.nl…the result is that a request ends on my NAS…
It seems to be that the Let’s Encrypt certificate is correctly installed.
What could be a possible solution? I have read many topics on the ha-community but did not find an answer…
Kind regards,
Pim.
