Hi there,
I have a static IP, a router on which I can do port-forwarding, my own domain with a subdomain currently containing a A-record pointing to my static IP.
I’ve setup a Raspberry Pi with Home Assistant OS (using the image provided on home-assistant.io in the installation tutorial).
I can access my home assistant remotely using ha.mydomain.com:8123 (which is not secure).
I added the letsencrypt addon in Home Assistant and set it up with my subdomain, mail, etc. I temporary opened port 80 in my router and pointed it to port 80 of the internal IP of home assistant.
Running the letsencrypt addon worked fine and the logs says it stored certificates in:
Certificate is saved at: /data/letsencrypt/live/ha.mydomain.com/fullchain.pem
Key is saved at: /data/letsencrypt/live/ha.mydomain.com/privkey.pem
But what’s up next?
I guess I’m only one or two steps away from having a working remote access setup!
