Hello, is there any way to add password for every tab view?
No. Goes in the same direction as this Feature request.
Ok, thanks
How long Feature request take time?
Can I manage another port for HASS ?
So I only use one server to control multiple HASS.
I am not sure I understand what you want to do, but you can specify the port for the web interface as described here: HTTP - Home Assistant
You can also setup different customized interface with HADashboard:
Thanks for information.
I want to make HASS control 2 different houses in one server.
So, if possible, I can make ex. hass.com:8123 for house 1 and hass.com:8124 for house 2.
So user from each house can only control their house, and it just require one server only to handle two HASS system.
This is probably my thought to resolve tab password that still in requesting feature.
Is that possible?
You can run multiple instances of Home Assistant on a system. The quickest solution to separate the instances would be to delegate the authentication to a proxy. As a starting point take a look at the Apache Configuration cookbook sample.
Thanks for your support, I’ll try that
Is there any solution to use IIS to be acts like Apache as proxy authentification?
