Problem solved using the securitas integration downloaded from Hacs.
Great news! How did you get that HACS install? I tried searching for it, but no joy. Thank you!
Thanks worked a charm for me
But I found it in HACS
Thanks! This worked great!
Prob late but is this integration still working? Tried this morning with my PT installation and when I add the sms code it gives an error âunknown errorâ and does nothing
Hi, it seems to be working fine for me when installed through HACS and used in France, but only for a short period of time. Relatively soon after a home assistant restart, I have the below error that is triggered every minute and it looks like the integration is unable to retrieve the true state of the alarm from that point on.
2024-01-07 12:41:48.401 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/config/custom_components/securitas/alarm_control_panel.py", line 146, in async_update_status
alarm_status = await self.client.update_overview(self.installation)
File "/config/custom_components/securitas/__init__.py", line 395, in update_overview
token = jwt.decode(
File "/usr/local/lib/python3.11/site-packages/jwt/api_jwt.py", line 210, in decode
decoded = self.decode_complete(
File "/usr/local/lib/python3.11/site-packages/jwt/api_jwt.py", line 151, in decode_complete
decoded = api_jws.decode_complete(
File "/usr/local/lib/python3.11/site-packages/jwt/api_jws.py", line 198, in decode_complete
payload, signing_input, header, signature = self._load(jwt)
File "/usr/local/lib/python3.11/site-packages/jwt/api_jws.py", line 254, in _load
raise DecodeError(f"Invalid token type. Token must be a {bytes}")
jwt.exceptions.DecodeError: Invalid token type. Token must be a <class 'bytes'>
Try upgrading the integration. That problem was fixed a few versions ago.
If that doesnât work please file an issue here: Issues ¡ guerrerotook/securitas-direct-new-api ¡ GitHub
Does anyone know if this works in Sweden? I am happy to be tester if helpful
Thanks for that integration!
I manage to make it work, but only on the way HA > Verisure. However, the status never changes.
If I change the alarm status physically, it never changes tooâŚ
So I am stuck with the disarmed status on my dashboardsâŚ
Does anybody has a lead on the potential problem please? (I tried to change check alarm panel status boolean, but it didnât helpâŚ)
It seems to be a Verisure problemâŚ
Their app has the same issueâŚ
In the end, it was my alarm SIM card that had a problem.
Everything is fine now!
Did you manage to get it working?
I am also in PT and I have the very same error.
Daniel
Yes I have it working for a while. Canât recall what I did but I believe I was adding the wrong pin. You have to add the pin they gave you when you setup your system. Hope it helps
@duquedaniel ^^
