Security breach
I’m seeing strange lines in the logs, as if someone is trying to send a byte string when accessing the server via IP, if I understand correctly.
Has anyone encountered this?
Summary
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 350, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 557, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message:
  Invalid method encountered:
    b'\x16\x03\x01'
2024-06-12 14:59:18.364 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x04\x01N\x1fBF\xcd\xe3'
2024-06-12 15:06:02.692 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:12:56.767 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:17:56.100 WARNING (MainThread) [homeassistant.components.http.security_filter] Filtered a potential harmful request to: /..%2F..%2F..%2F..%2F../etc/hosts
2024-06-12 15:17:56.417 WARNING (MainThread) [homeassistant.components.http.security_filter] Filtered a potential harmful request to: /..%2F..%2F..%2F..%2F../C:/Windows/win.ini
2024-06-12 15:20:02.203 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:26:55.356 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:34:02.694 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:41:10.560 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:48:02.846 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 15:54:59.939 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:01:56.363 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:09:09.394 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:16:07.968 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:23:27.787 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:30:24.407 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:37:27.271 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:44:38.382 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:51:41.166 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 16:58:43.948 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:06:04.883 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:13:11.812 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:20:35.923 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:27:39.111 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:34:44.455 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:41:41.289 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:49:02.834 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 17:56:03.572 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 18:03:14.221 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 18:10:27.757 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-12 18:17:17.705 ERROR (MainThread) [aiohttp.server] Error handling request
2024-06-13 07:43:26.822 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-13 21:54:35.409 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x03'
2024-06-13 22:59:45.115 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-13 23:00:54.996 WARNING (MainThread) [homeassistant.components.http.security_filter] Filtered a potential harmful request to: /api/hassio/app/.%252e/supervisor/info
2024-06-13 23:00:56.982 WARNING (MainThread) [homeassistant.components.http.security_filter] Filtered a request with an unsafe byte in path: /api/hassio/app/.%09./supervisor/info
2024-06-13 23:00:58.937 WARNING (MainThread) [homeassistant.components.http.security_filter] Filtered a request with an unsafe byte in path: /api/hassio_ingress/.%09./supervisor/info
2024-06-14 05:02:47.259 ERROR (MainThread) [aiohttp.server] Error handling request
aiohttp.http_exceptions.BadHttpMessage: 400, message:
  Pause on PRI/Upgrade:
    b''
2024-06-14 05:30:34.629 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x03'
2024-06-14 05:52:36.997 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-14 12:55:23.494 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x03'
2024-06-14 14:30:55.816 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x80'
2024-06-14 14:30:56.139 ERROR (MainThread) [aiohttp.server] Error handling request
    b''
2024-06-14 14:30:56.466 ERROR (MainThread) [aiohttp.server] Error handling request
    b'HELP'
2024-06-14 14:30:56.787 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03'
2024-06-14 14:30:57.204 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-14 14:30:57.214 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01\x01$\x01'
2024-06-14 14:30:57.522 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-14 14:30:57.837 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-15 05:20:42.337 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
2024-06-15 05:20:42.531 ERROR (MainThread) [aiohttp.server] Error handling request
    b'\x16\x03\x01'
I noticed the same thing in my home assistant today.
You can even see at some point a message with b'HELP'
