BTW is that a free tool you used there? Do you have a link - I would like to check it out…
I tried to update HA to version 2021.1.4. I got a failure message and the following log:
21-01-19 12:54:07 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:2021.1.4 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.1.4&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/homeassistant/raspberrypi3-homeassistant/manifests/2021.1.4”: Get “https://auth.docker.io/token?scope=repository%3Ahomeassistant%2Fraspberrypi3-homeassistant%3Apull&service=registry.docker.io”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”).
What does this mean?
That can be caused by an outdated version of HassOS, please make sure you are running HassOS 5.10 as well.
You are right. My current version is 5.9. But if I try the update to 5.10 I got also a failsure message with the log:
ERROR (MainThread) [supervisor.hassos] Home Assistant Operating System update failed with: signature verification failed: error:2E09A09E:CMS routines:CMS_SignerInfo_verify_content:verification failure
You can update HA OS manually using a USB key. See doc here: https://github.com/home-assistant/operating-system/blob/038f1b4bd69c952769fd020db0eae0f511570d19/Documentation/configuration.md
So, if the security issue is only affecting people with HA exposed to the internet/nabucasa, it should’ve been mentioned in the bulletin.
I’m probably not the only one that accesses HA only from within the network or via VPN.
Thanks! It works. HA OS is updated. I will try to update the HA Core now.
google seems to “pass” met the results on this “search”, can you give the link to it?
…and it also works!
It’s a custom integration and not an addon, you can find it in HACS and here → GitHub - custom-components/authenticated: A platform which allows you to get information about sucessfull logins to Home Assistant.
Doh, should have read on.
Is this supposed to introduce breaking changes? I’m now getting invalid configuration values notifications/errors
depends on which version you are upgrading from. Breaking changes for each release can be found in the release blogs.
Who said that’s the case?
I am having an issue with the 5.10 update (causes my PI4 to freeze, issue 1119 on github) Since you mention that this may also be a security issue, how can I help to provide more information to try and get this resolved? Looks like a lot of people responding on github with the same problem.
Again, thanks for all you do. It is much appreciated.
Bill
Nabu casa blog entry suggests this.
Not sure if intended.
I’m not mentioning it is a security issue. It said his issue with upgrading can happen on HassOS 5.9. This has no relation to the security bulletin given.
I am on 2020.12.7 and not seeing an update possible. I have reloaded the supervisor and restarted HA. Any other way to make sure I get this update?
Supervisor
Version
2020.12.7
Newest Version
2020.12.7
Channel
stable
