Hello guys! I’m buying a new door. The new door will be a security door, how can i integrate the lock with home assistant? Which lock i need to buy? Can i use shelly or similar?
You need to figure out what lock system that are in the door, since that limit the selection of smart locks.
You should probably contact the seller of the door and see what they can provide and then ask here if that solution is good with HA and maybe also in regards to security.
A smart lock is often both a mechanical lock and an electronic lock in one housing and the combination can make it less effective in both fields, so known security/safety problems are important to clear before buying.
