I am looking into options for a security system and I wanted to get experience on a few aspects with integration to home assistant.
Option 1: buy a zwave ready security panel and sensors then connect the zwave panel to the home assistant.
Option 2: buy zwave sensors and monitor them through home assistant.
My ideal setup for option 2 goes something like this in my head:
tablet mounted on the wall when you walk in the door, running home assistant. It a built in GUI that allows you to arm and disarm the alarm (siren connected to TB at raspberry pi) and the ability to monitor the system.
this may already exist but i couldn’t find any info on something like this. anyone have links or ideas?
I’m working on option 2 right now and have mixed feelings. It’s clearly not as robust and is prone to delays. Delay for sensor to get to Wink then another delay from Wink to Home Assistant. I’ve built a couple of cheap Android tablets to put around the house and control the system. Another issue that I’m trying to overcome is a passcode to disarm. Not sure exactly how to that piece yet. Right now I have a “Silence” icon that I’m using that will both disable and silence any alarms if they are going off.
I use standard Door, Window and motion. Previously these were connected to Alarm System but I moved them to RasPi. You can convert any existing equipment in this fashion. Just need to find power source for motions. Smoke and Heat detectors may require additional power as well .
I have motions in all rooms as well. Learned that I can use this to supplement presence detection. May utilize for future automation.
For example:
Phone wireless show wife home(Group Family Home)
Master motion ON, then OFF.
Hall motion ON, then OFF.
Living Motion ON then OFF. No Change 15min.
Phone Wireless show wife away(no door open so likely battery die or wifi off)
LIVING Motion ON then OFF
Hall Motion ON then OFF
Back door Open then close(possible someone left home)
IF no motion or presence after 15min ARM
Basically, only arm if door open procede wifi presence Away.
If not, ignore wifi and assume home and wait for door to open/close
The above example assumes everyone else already confirmed away(Group Family Away)
@tmjpugh Looking at your setup, does grouping the device entities make the alarm system arm and disarm if a single device enters the zone or only if both devices enter the zone?
