I strongly encourage home assistant developers (but also users) to read this article based on an avast report that present major security vulnerabilities found in home assistant (but not only) !
I am sorry, but to say that āmajor security vulnerabilitiesā have been found in home assistant is simply not true. What they report are for example publicly open SMB shares which is totally out of the hands of the home assistant developers, because if a user decides to expose that to the open world it is totally his own fault. If I leave my front door open and later complain about things being stolen I can make the door manufacturer responsible for that.
If users follow the guidelines to secure their installation less systems out there would be vulnerable to those obvious and simple to fix attack vectors mentioned in that article.
Home Assistant does not by default expose your MQTT server or SMB shares to the world. This is either done by the user or exposed by something like UPNP. There have been a number of threads about hacks and none have been the result of a issue in the home assistant code. The devs seem pretty responsive to security issues, changes have been made as a result of security issues that come up, these are usually covered in a blog post or release notes.
If you donāt explicity know what you are doing opening a port, do some research or ask for help on the implications.
First, GRC shields up test can scan your network for open ports. There should be none unless you opened it and know why its open. Open the link above and run the different tests (yellow box for UPNP test or grey bars for testing for open ports)
Second, from a remote IP (coffee shops are great for this) try to access your network. See how a stranger sees your IP. NMAP on a linux machine is a great tool for scanning your network and reporting the status. If you donāt have a portable linux machine put ubuntu or mint on a flash drive and boot from it, you can run off the flash drive.
Third, use shodan. Scan for your IP using their search tool. Also search for āHome Assistantā and āHomeassistantā. You will likely get a lot of results for the last two searches. Narrow the results using the filters for āTOP ORGANIZATIONSā (internet providers) and āTOP COUNTRIESā on the left hand side of the results page. You should be able to narrow the results quickly and see if your IP is listed.
Finally, you can look into a router with more advanced capabilities. I had a PFsense router in the past that would detect scans and block those IPs completely. The logging in PFsense is great also as you can see everything that is happening. I run a ubiquiti USG now and even with ports open they are limited to certain IPs so they donāt show as open in nmap scans, shodan scans or the GRC tool above unless ran from an IP I alllow.
In short, know what you are doing exposing your local network to the internet and check for gaps in your security and check often.
I want to say that these two responses and especially that from @silvrr are two of the best, most measured and constructive reponses to any of the many security āscareā posts that I have seen in the relatively short time I have been here.
And as someone who has been involved in some of those previous discussions, I agree entirely with everything you have written.
Remember I said that
I do though still have two points Iād like to make again. Firstly, it is in my opinion a little disingenuous to give advice that basically says āif you donāt understand the risks then donāt do itā. If you donāt understand the risks it is very likely that you donāt even know that there are risks. I know neither the devs nor anyone else intends it this way but reading the HA forums does give the impression that opening a port is kind of required to reap the full benefit of HA. And installing Samba even more so.
Secondly it isnāt the devs responsibility given that they do offer some advice in the docs, to hold anyoneās hand or to be responsible for how people open up thier systems. But I still maintain that that really shouldnāt be used as a defence. The more people put off HA because of what they read, accurate or not, the worse it will be. Conversely the more people who are happy with HA the better it will become and surely that is to some extent the devs responsibility? It is certainly their desire else they wouldnāt be constantly trying to make it better.
I am not ranting or complaining, I just think there is less of a clear line between who is and who isnāt responsible for the security of a system, because it plays into much more than whether an individual gets hacked.
First, HA by default (on any recent release) gives a persistent notification of a failed login attempt. I rarely use the frontend of my HA so I setup an automation to get an immediate notification when this happens.
The second tool comes from @leedus who has a custom component to log successful logins. I setup an automation to notify me of these also.
A few notes on the above.
1 there will be some white noise for a bit, initial logins from any device will give a notification, this should quiet down after you get your regular IPs logged.
2 internal access may show up from your router IP sometimes depending on how your network works. 3 3 you need a basic understanding of IPs and what private and public IP looks like. Knowing your internal subnet(s) and the commonly used IPs of your cell provider is helpful to avoid false alarms.
Some use cases actually might require you to open a port and that is why it is always recommended to protect your UI with a password. But it makes absolutely no sense to SMB to the outside of your network. There is simply no need for it. If, and only if you actually need Samba for example to edit your config filed, do that, but only do it on your own network and preferably restrict access to it. I heard that by default hass.io allows anonymous access to the share, so it is even more important to not open that port to the WAN.
Home assistant isnāt any different to using any other computer. If you open up a port to the outside world bad things might happen. There is nothing any developer in the world can do about but to point out the possible dangers.
The bottom of the line is, if you donāt know what you are doing, donāt do it and ask for help.
If you donāt know how to fix the breaks on your car it might not be the best idea to do so if you want to drive safely, right? Computers arenāt much different. Except that the likelihood of killing you isnāt as big.
Iād say that folks need to know their desire, extent of technical ability, and equipment. Why would your HA server be in the DMZ in any way? Iām even concerned for folks that are opening port 8123 ā even with a password or certs, etc. I highly recommend understanding what youāre doing and probing your public ports before throwing a server out to the WAN for all to hack away. Please have a look at VPNs as your alternative solution. Buying a capable router with built-in VPN or using DD-WRT firmware, etc. on some older router should enable you to connect to your home and access any INTERNAL server.
Ports 80 or 443 with the obvious 8123 being open should be sufficient for all call-back APIāsā¦ not sure what youāre running into but DMZ and no firewall for HASS is not the norm.
@louis-lau & @JZhass
I think our understanding of what a DMZ is is different. To me a DMZ does not mean there is no firewall. Itās just a (usually dedicated) subnet where hosts reside that are both accessible internally and externally. Forwarding / allowing traffic to the destination still has to be taken care of.
Why does this thread appear every few weeks? This topic has been beaten to death at this point and it always ends with a miss configuration on the users side.
Yeah, thatās what DMZ actually is. The way itās implemented in a lot of consumer routers though = all ports forwarded. Thatās just my experience.
I get what youāre sayingā¦ the DMZ can be protected as well. Either way, Iām not a big fan of throwing my HA site on the WAN unless Iām whitelisting external IPās. I wouldnāt do reverse proxy to the HA box, etc. Just not worth itā¦ VPN at home is much more secure.
