Hi all,
I try to call the webhook api from my nas synology suveillance station, unfortunately surveillance station cannot pass header for authantication, that the reasion why a add a trusted network. On this server i also have my nginx server for the reverse proxy to my home assistant.
After adding the bellow configuration in my config file i can now always bypass the login page.
I don’t if it’s because there is something wrong in my configuration or if it because my nginx server and the surveillance station is on the same server and trusted the reverse proxy server is not a good idea.
configuration.yaml
homeassistant:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- XXX.XXX.XXX.10
http:
base_url : https://xxx.xxx.com
use_x_forwarded_for: true
trusted_proxies: XXX.XXX.XXX.10
nginx conf :
server {
listen 80;
server_name xxx.xxx.com;
location / {
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
ssl_certificate /usr/...fullchain.pem;
ssl_certificate_key /usr/.../privkey.pem;
location / {
proxy_pass http://XXX.XXX.XXX.6:8123;
proxy_http_version 1.1;
proxy_buffering off;
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forward-For $proxy_add_x_forwarded_for;
Thanks in advance for your insight
G.
