This error clears from the log following an HA restart and has only appeared occasionally, but when it shows up it logs dozens per second. Anyone seen this before, or have a guess on its origin?
2019-10-31 08:08:02 ERROR (MainThread) [frontend.js.latest.201910022] http://my.url/frontend_latest/app.37dcadb7.js:724:266382 SecurityError: Attempt to use history.pushState() more than 100 times per 30 seconds
it happens when I swipe between the different lovelace views. If I remove cch then I’m not able to slide and I don’t get the error.
I’m not sure if cch is causing the issue. It happens only when I swipe
mayker
(maykar (pronounced "maker" with a southern accent))
7
could you make an issue on the github and fill the needed info, also include whether this happens to you with just the swipe animation or with others as well.
has this issue been solved somehow< Im still seeing it in the log and have no idea what’s causing it or when it happens, other than the timestamp:
2020-02-25 03:41:59 ERROR (MainThread) [frontend.js.latest.202001303] https://redacted.duckdns.org:port/frontend_latest/app.119d932a.js:726:257665 SecurityError: Attempt to use history.pushState() more than 100 times per 30 seconds
also, this is preceded and followed by te Plex sensor not being able to reach the server
