Think I have the right place. as I keep repeating I am a newbie making gradual progress. I am try to add this custom integration . In the README file it tells me to…
To add SecuritySpy to your installation, go to the Integrations page inside the configuration panel and add a Server by providing the IP Address, Port Username and Password for the SecuritySpy Webserver you set up above.
I am probably to much of a newbie… but I sure cant find any way to “add a Server”. Any help would naturally be appreciated
I don’t use this integration but if it is like any of the others that have to be set up through the UI those instructions are a bit sparse and leave an important step out.
Once you have added the integration through HACS and restarted, go to the Configuration / Integrations page and click the + Add Integration button in the lower right corner of the page. Search for SecuritySpy and add it. This should then prompt you for the server details.
Thanks… It’s probably my lack of knowledge but I can no manage to follow the included instructions on that… Its says
This Integration is not part of the default HACS store yet. You can add is a Customer Integration in HACS by adding https://github.com/briis/securityspy to HACS under settings.
I have been Totally unable to so that . I can get the file area but I can’t add it… Real learning experience…
