I’m building an integration, to switch my power-supply on/off, depending if my laptop is turned on/off.
I was thinking of using the “ping” command ( Ping (ICMP) - Home Assistant ), so I would have a binary sensor, telling me the “state” of the laptop.
However, because this is a company laptop, ping is disabled (I work from home, 95% of my time)
(I’m local admin on my PC, but company policy locked all kind of things !)
I tried to install a windows companion app, but this needs to open a port to communicate between the windows PC and HA.
I can install software, but opening ports is blocked.
(I can access file-shares on my NAS, install my local printers, do whatever I want on the internet …)
Anyone got a “workaround” for this ? The only thing I want is to let HA see if my laptop is on/off.
I can program a bit in VB.NET, if needed …
Thanks, but already tested this version, it doesn’t work on my company laptop, due to some ports that are blocked.
In the meantime, I found “IOT Link”, this one seems to work, I see messages coming in on MQTT !
However, only one entitity does work, the one that shows online/offline.
(power status and battery remaining-percent are “unknown”)
