See what Hacs components are used/unused?
I have tried many HACS mods over the years. The update list become long at times and Im unsure which I actually use. Is there a neat way to check?
Hi, HACS has been renamed to Marketplace recently.
Opening it shows what you have installed, if there is an update for it and what else you can install.
Open your Home Assistant instance and browse the Marketplace.
I guess you misunderstood the question. it’s “I downloaded and installed FooBar-Card from Marketplace(HACS). Do I still use it in any of my dashboards ??” Integrations from Maketplace/HACS are easier to spot…
I am pretty sure sppok does what you want, not 100% sure though.
Huh, looks useful, gonna try it!
And this… :slight_smile:
loryanstrant/HA-CustomComponentMonitor: Reports on whether you are using your Home Assistant custom components
It found some but cant tell me which?
