I was able to get this device working and integrated with HomeAssistant. Sharing to hopefully help save others some time…
substitutions:
friendly_name: Seeed Xaio w/Camera 123456
# Pin definitions
camera_sda_pin: GPIO40
camera_scl_pin: GPIO39
camera_data_pins: GPIO15, GPIO17, GPIO18, GPIO16, GPIO14, GPIO12, GPIO11, GPIO48
camera_vsync_pin: GPIO38
camera_href_pin: GPIO47
camera_pclk_pin: GPIO13
camera_xclk_pin: GPIO10 # Assign the appropriate GPIO pin for xclk
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
platformio_options:
# board_build.flash_mode: dio
board_build.mcu: esp32s3
build_flags: -DBOARD_HAS_PSRAM
board_build.arduino.memory_type: qio_opi
board_build.f_flash: 80000000L
board_build.flash_mode: qio
# https://wiki.seeedstudio.com/XIAO_ESP32S3_esphome/
project:
version: '1.0'
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
#version: latest
wifi:
ssid: !secret wifi_ssid
api:
encryption:
key: <your api key here>
ota: # Allow Over-The-Air updates
- platform: esphome
logger:
web_server:
- platform: uptime
icon: mdi:clock-start
entity_category: "diagnostic"
update_interval: 60s
- platform: uptime
name: "ESP32 Camera Uptime Sensor"
icon: mdi:information
- platform: wifi_signal
name: "ESP32 Camera WiFi Signal"
text_sensor:
- platform: wifi_info
ip_address:
name: "Wifi IP Address"
ssid:
icon: mdi:ip-outline
entity_category: diagnostic
mac_address:
name: "WiFi MAC Address"
# Camera configuration
esp32_camera:
name: "Seeed XIAO ESP32-S3 Camera"
external_clock:
pin: ${camera_xclk_pin}
frequency: 12MHz
i2c_pins:
sda: ${camera_sda_pin}
scl: ${camera_scl_pin}
data_pins:
- GPIO15
- GPIO17
- GPIO18
- GPIO16
- GPIO14
- GPIO12
- GPIO11
- GPIO48
vsync_pin: ${camera_vsync_pin}
href_pin: ${camera_href_pin}
pixel_clock_pin: ${camera_pclk_pin}
resolution: 1280X1024
jpeg_quality: 10
max_framerate: 15 fps
switch:
optimistic: True
- platform: restart
name: "ESP32 Camera Restart"
My rudimentary lovelace card
- type: sections
max_columns: 4
icon: mdi:camera
path: seeed-w-camera
title: Seeed w Camera
sections:
- type: grid
cards:
- type: heading
heading: New section
- type: tile
entity: sensor.esphome_web_20c368_wifi_ip_address
- type: tile
entity: sensor.esphome_web_20c368_wifi_mac_address
- type: tile
entity: sensor.esphome_web_20c368_wifi_ssid
- type: tile
entity: sensor.esphome_web_20c368_esp32_camera_wifi_signal
- type: tile
entity: sensor.esphome_web_20c368_uptime
- type: tile
entity: button.esphome_web_20c368_restart
- type: grid
cards:
- type: heading
- type: tile
entity: camera.esphome_web_20c368_seeed_xiao_esp32_s3_camera
show_entity_picture: true
- camera_view: live
type: picture-glance
title: SecretAgent
image: https://demo.home-assistant.io/stub_config/kitchen.png
entities:
- binary_sensor.remote_ui
- sensor.sun_next_dawn
camera_image: camera.esphome_web_20c368_seeed_xiao_esp32_s3_camera
sonra1
(Sonra1)
March 28, 2025, 4:58pm
3
Hi
Did you use a general ov5640 camera or the xiao ov5640 ?
I tried to connect a general ov5640 and get error
E (17) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
E (38) gdma: gdma_disconnect(314): no peripheral is connected to the channel
Camera init failed with error 0x105
Thanks Doron
latest updates
esphome:
platformio_options:
project:
version: '1.0'
esp32:
framework:
type: arduino
version: latest
substitutions:
friendly_name: Seeed Xaio w/Camera 20C368
# Pin definitions
camera_xclk_pin: GPIO10 #External clock
camera_power_pin: GPIO1 #use to turn camera on an off?
user_led_pin: GPIO21
camera_max_framerate: '15fps'
camera_jpeg_quality: '10'
camera_vertical_flip: 'true'
camera_horizontal_mirror: 'true'
camera_contrast: '0'
camera_brightness: '0'
camera_saturation: '0'
camera_special_effect: 'none'
camera_aec_mode: 'auto'
camera_aec2: 'false'
camera_ae_level: '0'
camera_aec_value: '300'
camera_agc_mode: 'auto'
camera_agc_value: '0'
camera_agc_ceiling: '2x'
camera_white_balance: 'auto'
esp32_camera:
#connection options
data_pins:
- GPIO15
- GPIO17
- GPIO18
- GPIO16
- GPIO14
- GPIO12
- GPIO11
- GPIO48
external_clock:
frequency: 12MHz
i2c_pins:
#power_down_pin: !!! done by software switch GPIO1
#frame settings
max_framerate: ${camera_max_framerate}
idle_framerate: 0.1fps #default
#Image Settings
jpeg_quality: ${camera_jpeg_quality}
vertical_flip: ${camera_vertical_flip}
horizontal_mirror: ${camera_horizontal_mirror}
brightness: ${camera_brightness}
contrast: ${camera_contrast}
saturation: ${camera_saturation}
special_effect: ${camera_special_effect}
#Exposure settings
aec_mode: ${camera_aec_mode}
aec2: ${camera_aec2}
ae_level: ${camera_ae_level}
aec_value: ${camera_ae_level}
#Sensor gain settings
agc_mode: ${camera_aec_mode}
agc_gain_ceiling: ${camera_agc_ceiling}
agc_value: ${camera_agc_value}
#White balance settings
wb_mode: ${camera_white_balance}
web_server:
packages:
device_base: !include soup_device_base.yaml
camera_config: !include z_config_ov5640_camera.yaml
switch:
optimistic: True
turn_on_action:
then:
- switch.turn_on: camera_power_output
turn_off_action:
then:
- switch.turn_off: camera_power_output
- platform: restart
- platform: gpio
pin: ${camera_power_pin}
turn_on_action: # Reset values to default
- lambda: |-
// Set camera to default values using substitutions and proper conversions
id(seeed_camera).set_contrast(0);
id(seeed_camera).set_brightness(0);
- switch.turn_off: reset_camera_settings # Ensure the switch is momentary
light:
- platform: monochromatic
output: onboard_user_led
output:
- platform: ledc
pin: ${user_led_pin}
frequency: 5000
inverted: true #aligns switch and LED
- platform: homeassistant
entity_id: input_number.camera_jpeg_quality
entity_id: input_boolean.camera_vertical_flip
entity_id: input_boolean.camera_horizontal_mirror
entity_id: input_number.camera_brightness
entity_id: input_number.camera_contrast
entity_id: input_number.camera_saturation
entity_id: input_select.camera_special_effect
entity_id: input_select.camera_aec_mode
entity_id: input_boolean.camera_aec2
entity_id: input_number.camera_ae_level
entity_id: input_number.camera_ae_value
entity_id: input_select.camera_agc_mode
entity_id: input_number.camera_agc_ceiling
entity_id: input_number.camera_agc_value
entity_id: input_select.camera_white_balance
frabar55
(Francesco Mongelli)
August 1, 2025, 4:03pm
5
Hi Steve, I’m trying to follow your solution but without success. I always receive an error : [esp32_camera:199]: Got invalid frame from camera! I have the same your hardware. Could you help me?
saxbyandrew
(Andrew Saxby)
September 29, 2025, 3:35am
6
Thanks for this post it saved me a lot of time, messing with GPIO settings. However if I may ask a couple of questions please"
I have Seeed Studio XIAO ESP32S3 Sense with a OV5640.
I does NOT have an external antenna.
It runs streams the image painfully slow, I get one image every 10 seconds, I’m I just expecting to much from this device? Has anyone had a smooth video stream?
Many Thanks for any suggestions of feedback
I’m not really using it in ‘production’. It seemed slow overall… antenna may help?
Chompy80
(Chompy80)
October 24, 2025, 12:23am
8
I’m attempting to get this to work using your latest updates posted on June 29th. When I go to compile I get the error, “Error reading file /config/esphome/soup_device_base.yaml: [Errno 2] No such file or directory: ‘/config/esphome/soup_device_base.yaml’”
I’m assuming these files are needed in order to use the code:
packages:
I’ve been offline with some home/family stuff. If it’s the same exact hardware - not sure why my provided code wouldn’t work. What do you get or see?
soup_base is a file I include in all my esps… just standard stuff for ESP diagnostics
type or paste code here
# Enable Home Assistant API
wifi:
api:
encryption:
key: 1<your key here>
on_client_connected:
then:
- logger.log: "Wi-Fi connected"
- component.update: wifi_ip_address
- platform: esphome
logger:
### SENSORS
- platform: uptime
accuracy_decimals: 0
internal: true
filters:
- delta: 60 # only push if uptime changes by 60s
- platform: internal_temperature
name: "ESP Onboard Temp (°C)"
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: mdi:temperature-celsius
update_interval: 600s
device_class: temperature
state_class: measurement
on_value:
then:
- component.update: esp_onboard_temp_f
name: "ESP Onboard Temp (°F)"
icon: mdi:temperature-fahrenheit
unit_of_measurement: "°F"
update_interval: never # [derived from °C]
lambda: |-
if (!id(esp_onboard_temp_c).has_state()) return NAN;
return id(esp_onboard_temp_c).state * 9.0 / 5.0 + 32.0;
name: "WiFi Signal RSSI"
icon: mdi:wifi-strength-outline
device_class: signal_strength
filters:
- delta: 2 # only push if RSSI changes by 2 dBm
- platform: copy
source_id: wifi_signal_db
name: "WiFi Signal %"
unit_of_measurement: "%"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
- delta: 2
### device_class: "" # 👈 Prevents Home Assistant from validating unit
### TEXT SENSORS
text_sensor:
name: "ESP Uptime (DHM)"
icon: mdi:clock-outline
update_interval: 60s # refresh every minute
lambda: |-
uint32_t uptime_sec = (uint32_t)id(esp_uptime).state;
uint32_t days = uptime_sec / 86400;
uint32_t hours = (uptime_sec % 86400) / 3600;
uint32_t minutes = (uptime_sec % 3600) / 60;
char buffer[32];
snprintf(buffer, sizeof(buffer), "%ud %02uh %02um", days, hours, minutes);
return std::string(buffer);
- platform: version
name: "ESP Firmware Version"
icon: mdi:information-variant
# update_interval: [static value]
hide_timestamp: true
name: "ESP WiFi IP Address"
update_interval: 120s
lambda: |-
static std::string last_ip;
std::string current_ip = id(wifi_ip_address_raw).state;
if (current_ip.empty() || current_ip == last_ip) return {};
last_ip = current_ip;
return current_ip;
ip_address:
name: "WiFi IP Address (raw)"
internal: True
ssid:
# update_interval: [event-driven]
mac_address:
name: "WiFi MAC Address (compact)"
lambda: |-
auto mac = id(wifi_mac_address).state;
std::string stripped_mac;
for (char c : mac) if (c != ':') stripped_mac += c;
return stripped_mac;
name: "WiFi MAC Address [6]"
lambda: |-
return stripped_mac.substr(stripped_mac.length() - 6);
#### BINARY SENSORS
binary_sensor:
- platform: status
name: "ESP HA Connection Status"
icon: mdi:cloud-check
device_class: connectivity
### SOFTWARE BUTTONS
button:
- platform: restart
icon: mdi:power-cycle
on_press:
then:
- logger.log:
format: "Restart triggered on ESP [${friendly_name}]"
here’s the z_config ov5640 file… sorry about forgetting to include it
input_number:
min: 10
max: 63
step: 1
name: "Max Framerate"
min: 10
max: 30
step: 1
camera_idle_framerate:
name: "Idle Framerate"
min: 0.1
max: 30
step: 1
camera_ae_level:
min: -2
max: 2
step: 1
camera_aec_level:
min: 0
max: 1200
step: 100
camera_agc_level:
min: 0
max: 30
step: 1
camera_brightness:
min: -2
max: 2
step: 1
camera_contrast:
min: -2
max: 2
step: 1
camera_saturation:
min: -2
max: 2
step: 1
camera_quality:
min: 10
max: 63
step: 1
input_boolean:
camera_awb_gain:
camera_aec2:
input_select:
camera_aec_mode:
options:
- "auto"
- "manual"
camera_agc_mode:
options:
- "auto"
- "manual"
camera_agc_ceiling:
options:
- "2x"
- "4x"
- "8x"
- "16x"
- "32x"
- "64x"
- "128x"
options:
- "none"
- "negative"
- "grayscale"
- "red_tint"
- "green_tint"
- "blue_tint"
- "sepia"
options:
- "auto"
- "sunny"
- "cloudy"
- "office"
- "home"
1Richter
(1 Richter)
December 6, 2025, 1:54pm
12
I have a Freenove ESP32-S3 clone + ov5640 (aliexpress) with following config for Homeassistant 2025.12 and latest esphome. But i cant get the homeassistant camera settings to apply to the ov5640. I cant toggle switches, and these show up in the esp32 logs, but e.g. the vertical flip isnt applied to the camera (feed).
I tried to reduce i2c speed to 100kHz, enabled PSRAM to octal (for my s3-N16-R8) and changed default brightnes to 2, because the ov5640 feed is so dark.
But my “speed”, as mentioned in october by steve, is sufficient and i get a smooth video stream.
Can someone please suggest any changes, so my ov5640 is not so dimm (ov2640 and ov2540 are working flawlessly) AND:
make the switches in homeassistant (or esphome ui) apply to the live camera feed?
these are my logs
[esp32_camera:207]: Got Image: len=12125
[number:065]: 'Camera Brightness': Setting value
[number:124]: New value: 2.000000
[number:035]: 'Camera Brightness': Sending state 2.000000
but these dont seem to apply to the cam.
esphome:
friendly_name: esp32-s3
on_boot:
priority: 600
then:
- light.turn_on:
brightness: 60%
red: 0%
green: 100%
blue: 0%
- lambda: id(esp32s3_cam).set_aec_mode(esphome::esp32_camera::ESP32_GC_MODE_AUTO);
- lambda: id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_AUTO);
- lambda: id(esp32s3_cam).set_brightness(2);
- delay: 1s
- light.turn_off: onboard_led
esp32:
framework:
type: esp-idf
psram:
mode: octal
speed: 80MHz
logger:
level: VERBOSE
api:
encryption:
key: "xyz="
ota:
- platform: esphome
password: "my_pw"
wifi:
domain: .dns.tld
manual_ip:
static_ip: 192.168.1.2
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 192.168.1.1
dns2: 8.8.8.8
ap:
ssid: "Esp32-S3 Fallback Hotspot"
password: "my_pw"
captive_portal:
# lowered i2c clock speed
i2c:
- id: camera_i2c
sda: GPIO4
scl: GPIO5
frequency: 100kHz
# RGB LED
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO48
num_leds: 1
chipset: WS2812
name: "Onboard RGB LED"
restore_mode: RESTORE_DEFAULT_OFF
esp32_camera:
external_clock:
pin: GPIO15
frequency: 20MHz
i2c_id: camera_i2c
data_pins: [GPIO11, GPIO9, GPIO8, GPIO10, GPIO12, GPIO18, GPIO17, GPIO16]
vsync_pin: GPIO6
href_pin: GPIO7
pixel_clock_pin: GPIO13
# Octal PSRAM is required for the 5MP sensor
frame_buffer_location: PSRAM
# Frame settings
max_framerate: 15fps
# Low idle framerate cools the camera when you aren't looking at it
# Image Settings
resolution: 640x480
jpeg_quality: 10
vertical_flip: false
horizontal_mirror: false
# Defaults, overriden by - on_boot: above
brightness: 2
contrast: 0
saturation: 0
aec_mode: auto
wb_mode: auto
# Frigate config
web_server:
port: 80
include_internal: False
esp32_camera_web_server:
- port: 8080
mode: stream
- port: 8081
mode: snapshot
# Sensors
- platform: uptime
internal: true
update_interval: 10s
# Homeassistant Controls
number:
name: "Camera Contrast"
entity_category: config
icon: mdi:contrast-circle
min_value: -2
max_value: 2
step: 1
initial_value: 0
optimistic: true
set_action:
- lambda: id(esp32s3_cam).set_contrast(x);
name: "Camera Brightness"
icon: mdi:brightness-6
min_value: -2
max_value: 2
step: 1
initial_value: 0
optimistic: true
set_action:
- lambda: id(esp32s3_cam).set_brightness(x);
name: "Camera Saturation"
icon: mdi:palette
min_value: -2
max_value: 2
step: 1
initial_value: 0
optimistic: true
set_action:
- lambda: id(esp32s3_cam).set_saturation(x);
switch:
name: "Camera Vertical Flip"
icon: mdi:flip-vertical
optimistic: true
turn_on_action:
- lambda: id(esp32s3_cam).set_vertical_flip(true);
turn_off_action:
- lambda: id(esp32s3_cam).set_vertical_flip(false);
name: "Camera Horizontal Mirror"
icon: mdi:flip-horizontal
optimistic: true
turn_on_action:
- lambda: id(esp32s3_cam).set_horizontal_mirror(true);
turn_off_action:
- lambda: id(esp32s3_cam).set_horizontal_mirror(false);
- platform: restart
name: "Restart Camera Board"
select:
optimistic: true
options:
- "None"
- "Negative"
- "Grayscale"
- "Red Tint"
- "Green Tint"
- "Blue Tint"
- "Sepia"
initial_option: "None"
set_action:
- lambda: |-
if (x == "Negative") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_NEGATIVE);
else if (x == "Grayscale") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_GRAYSCALE);
else if (x == "Red Tint") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_RED_TINT);
else if (x == "Green Tint") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_GREEN_TINT);
else if (x == "Blue Tint") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_BLUE_TINT);
else if (x == "Sepia") id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_SEPIA);
else id(esp32s3_cam).set_special_effect(esphome::esp32_camera::ESP32_SPECIAL_EFFECT_NONE);
name: "Camera White Balance"
optimistic: true
icon: mdi:white-balance-sunny
options:
- "Auto"
- "Sunny"
- "Cloudy"
- "Office"
- "Home"
initial_option: "Auto"
set_action:
- lambda: |-
if (x == "Sunny") id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_SUNNY);
else if (x == "Cloudy") id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_CLOUDY);
else if (x == "Office") id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_OFFICE);
else if (x == "Home") id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_HOME);
else id(esp32s3_cam).set_wb_mode(esphome::esp32_camera::ESP32_WB_MODE_AUTO);
Try the code attached, I had a hard time to figure this out with and ChatGPT let me down all the time. In the end, forget the flip switches and only initialized flip or mirror once. I tried my not working code also with an OV5640 and it did not work but as with the init values only, it worked on the OV3660, so I assume it will work on the OV5640 aswell. In an earlier version I even got brightness, contrast and saturation working but in all my hundreds of changes, I broke something. You loose some, you win some
esphome:
platformio_options:
esp32:
framework:
type: esp-idf
substitutions:
camera_resolution: 1280X1024
psram:
mode: octal
speed: 80MHz
script:
# Apply all "color-ish" settings together, every time any slider changes
- id: apply_color_settings
mode: restart
then:
- lambda: |-
id(seeed_camera).set_brightness((int) id(cam_brightness_num).state);
id(seeed_camera).set_contrast((int) id(cam_contrast_num).state);
id(seeed_camera).set_saturation((int) id(cam_saturation_num).state);
- id: apply_camera_settings
mode: restart
then:
- lambda: |-
id(seeed_camera).set_jpeg_quality((int) id(cam_jpeg_quality_num).state);
- script.execute: apply_color_settings
i2c:
- id: camera_i2c
frequency: 100kHz
esp32_camera:
i2c_id: camera_i2c
data_pins:
- GPIO15
- GPIO17
- GPIO18
- GPIO16
- GPIO14
- GPIO12
- GPIO11
- GPIO48
external_clock:
frequency: 20MHz
# If your wiring supports it, consider letting the component manage PWDN:
power_down_pin: ${camera_power_pin}
on_stream_start:
then:
- delay: 200ms
- script.execute: apply_camera_settings
resolution: ${camera_resolution}
jpeg_quality: 10
vertical_flip: true
brightness: 0
contrast: 0
saturation: 0
special_effect: none
aec_mode: auto
aec2: false
ae_level: 0
aec_value: 300
agc_mode: auto
agc_gain_ceiling: 2x
agc_value: 0
wb_mode: auto
web_server:
port: 80
switch:
- platform: restart
turn_on_action:
- lambda: |-
id(cam_brightness_num).publish_state(0);
id(cam_contrast_num).publish_state(0);
id(cam_saturation_num).publish_state(0);
id(cam_jpeg_quality_num).publish_state(10);
number:
name: "Cam Brightness"
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
name: "Cam Contrast"
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
name: "Cam Saturation"
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
name: "Cam JPEG Quality"
min_value: 10
max_value: 63
step: 1
restore_value: true
initial_value: 10
set_action:
light:
output:
- platform: ledc
frequency: 5000
inverted: true
wifi:
api:
encryption:
key: "your key"
then:
ota:
- platform: esphome
logger:
- platform: uptime
internal: true
filters:
- delta: 60
on_value:
then:
lambda: |-
filters:
- delta: 2
- platform: copy
filters:
- delta: 2
text_sensor:
lambda: |-
char buffer[32];
- platform: version
lambda: |-
return current_ip;
ip_address:
internal: true
ssid:
mac_address:
lambda: |-
lambda: |-
name: "Camera Resolution (configured)"
icon: mdi:image-size-select-large
lambda: |-
return std::string("${camera_resolution}");
binary_sensor:
- platform: status
button:
- platform: restart
on_press:
then:
- logger.log:
Here is the update code, mostly all things are working via the switches except the flip or mirror or resolution, this has to be hardcoded in the yaml file and compiled.
Thank you Steve_Campbell
Firmware and yaml config for an esp32 sense xiao to integrate in Home Assistant or ESPHome
esphome:
platformio_options:
on_boot:
priority: -100
then:
- lambda: |-
id(g_vflip) = false;
id(g_hmirror) = true;
esp32:
framework:
type: arduino
version: latest
substitutions:
psram:
mode: octal
speed: 80MHz
globals:
- id: g_vflip
type: bool
restore_value: false
initial_value: "false"
- id: g_hmirror
type: bool
restore_value: true
initial_value: "true"
script:
mode: restart
then:
- lambda: |-
const char *wb = id(cam_white_balance).current_option();
const char *fx = id(cam_effect).current_option();
using namespace esphome::esp32_camera;
// WB
if (strcmp(wb, "sunny") == 0) id(seeed_camera).set_wb_mode(ESP32WhiteBalanceMode::ESP32_WB_MODE_SUNNY);
else if (strcmp(wb, "cloudy") == 0) id(seeed_camera).set_wb_mode(ESP32WhiteBalanceMode::ESP32_WB_MODE_CLOUDY);
else if (strcmp(wb, "office") == 0) id(seeed_camera).set_wb_mode(ESP32WhiteBalanceMode::ESP32_WB_MODE_OFFICE);
else if (strcmp(wb, "home") == 0) id(seeed_camera).set_wb_mode(ESP32WhiteBalanceMode::ESP32_WB_MODE_HOME);
else id(seeed_camera).set_wb_mode(ESP32WhiteBalanceMode::ESP32_WB_MODE_AUTO);
// FX
if (strcmp(fx, "negative") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_NEGATIVE);
else if (strcmp(fx, "grayscale") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_GRAYSCALE);
else if (strcmp(fx, "red_tint") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_RED_TINT);
else if (strcmp(fx, "green_tint") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_GREEN_TINT);
else if (strcmp(fx, "blue_tint") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_BLUE_TINT);
else if (strcmp(fx, "sepia") == 0) id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_SEPIA);
else id(seeed_camera).set_special_effect(ESP32SpecialEffect::ESP32_SPECIAL_EFFECT_NONE);
ESP_LOGI("cam_apply", "apply_camera_settings() finished");
mode: restart
then:
- lambda: |-
id(seeed_camera).set_vertical_flip(id(g_vflip));
id(seeed_camera).set_horizontal_mirror(id(g_hmirror));
esp32_camera:
data_pins:
- GPIO15
- GPIO17
- GPIO18
- GPIO16
- GPIO14
- GPIO12
- GPIO11
- GPIO48
external_clock:
frequency: 20MHz
i2c_pins:
# power_down_pin: ${camera_power_pin}
on_stream_start:
then:
- delay: 200ms
jpeg_quality: 10
horizontal_mirror: true
brightness: 0
contrast: 0
saturation: 0
aec_mode: auto
aec2: false
ae_level: 0
aec_value: 300
agc_mode: auto
agc_value: 0
wb_mode: auto
web_server:
port: 80
switch:
turn_on_action:
- lambda: |-
id(cam_white_balance).publish_state("auto");
id(cam_effect).publish_state("none");
name: "Cam Vertical Flip"
internal: true
restore_mode: ALWAYS_OFF
lambda: |-
return id(g_vflip);
turn_on_action:
- lambda: |-
id(g_vflip) = true;
turn_off_action:
- lambda: |-
name: "Cam Horizontal Mirror"
internal: true
restore_mode: ALWAYS_ON
lambda: |-
return id(g_hmirror);
turn_on_action:
- lambda: |-
turn_off_action:
- lambda: |-
id(g_hmirror) = false;
number:
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
min_value: -2
max_value: 2
step: 1
restore_value: true
initial_value: 0
set_action:
min_value: 10
max_value: 63
step: 1
restore_value: true
initial_value: 10
set_action:
select:
name: "Cam White Balance"
optimistic: true
restore_value: true
options: [auto, sunny, cloudy, office, home]
initial_option: auto
set_action:
name: "Cam Special Effect"
optimistic: true
restore_value: true
options: [none, negative, grayscale, red_tint, green_tint, blue_tint, sepia]
initial_option: none
set_action:
light:
output:
- platform: ledc
frequency: 5000
inverted: true
wifi:
api:
encryption:
key: your key
then:
ota:
- platform: esphome
logger:
- platform: uptime
internal: true
filters:
- delta: 60
on_value:
then:
lambda: |-
filters:
- delta: 2
- platform: copy
filters:
- delta: 2
text_sensor:
lambda: |-
char buffer[32];
- platform: version
lambda: |-
return current_ip;
ip_address:
internal: true
ssid:
mac_address:
lambda: |-
lambda: |-
lambda: |-
binary_sensor:
- platform: status
button:
- platform: restart
on_press:
then:
- logger.log:
Hey, how about camera’s temperature? got few, and they are extremely hot.
it’s a pretty slow device IMO. I do have the antenna. Not played with this much more since proof of concept.
I’d have to fire it back up. I think i recall something about those cams running not.
