Seeedstudio 7.5" epaper with ESP32 life360
I’m using Seeedstudio 7.5" epaper with ESP32C to display info from Life360 - So I can see in the morning if my older teenagers are home after working in a nightclub - So I’ve managed to display the info in HA but doesnt seem to give nothing but errors when trying to get it to display on the epaper. no matter i code it as a sensor or a text.sensor I get nothing but errors. I’m show im missing something simple
Please please stop posting pictures of text files.
Full yaml (properly quoted)
Full log (properly quoted)
Also note that 7.50inv2 is not a valid model (case matters)
Seeed epaper wilki has it a 7.50inv2 in their sample code.
https://wiki.seeedstudio.com/xiao_075inch_epaper_panel/
Full Log
INFO ESPHome 2025.4.0
INFO Reading configuration /config/esphome/life360.yaml...
WARNING GPIO8 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
INFO Compiling app...
Processing life360 (board: esp32-c3-devkitm-1; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.4
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.3.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.6
|-- SPI @ 2.0.0
Compiling .pioenvs/life360/src/main.cpp.o
/config/esphome/life360.yaml: In lambda function:
/config/esphome/life360.yaml:106:93: error: no matching function for call to 'esphome::display::Display::print(int, int, esphome::font::Font*&, esphome::Color&, esphome::display::TextAlign, float&)'
         it.print(120, 20, id(font_weekday), color_black, TextAlign::TOP_CENTER, id(myLife360).state);
In file included from src/esphome.h:17,
                 from src/main.cpp:3:
src/esphome/components/display/display.h:347:8: note: candidate: 'void esphome::display::Display::print(int, int, esphome::display::BaseFont*, esphome::Color, esphome::display::TextAlign, const char*, esphome::Color)'
   void print(int x, int y, BaseFont *font, Color color, TextAlign align, const char *text,
src/esphome/components/display/display.h:347:8: note:   no known conversion for argument 6 from 'float' to 'const char*'
src/esphome/components/display/display.h:359:8: note: candidate: 'void esphome::display::Display::print(int, int, esphome::display::BaseFont*, esphome::Color, const char*, esphome::Color)'
   void print(int x, int y, BaseFont *font, Color color, const char *text, Color background = COLOR_OFF);
src/esphome/components/display/display.h:359:8: note:   no known conversion for argument 5 from 'esphome::display::TextAlign' to 'const char*'
src/esphome/components/display/display.h:369:8: note: candidate: 'void esphome::display::Display::print(int, int, esphome::display::BaseFont*, esphome::display::TextAlign, const char*)'
   void print(int x, int y, BaseFont *font, TextAlign align, const char *text);
src/esphome/components/display/display.h:369:8: note:   candidate expects 5 arguments, 6 provided
src/esphome/components/display/display.h:378:8: note: candidate: 'void esphome::display::Display::print(int, int, esphome::display::BaseFont*, const char*)'
   void print(int x, int y, BaseFont *font, const char *text);
src/esphome/components/display/display.h:378:8: note:   candidate expects 4 arguments, 6 provided
*** [.pioenvs/life360/src/main.cpp.o] Error 1
========================== [FAILED] Took 3.68 seconds ==========================
esphome:
  friendly_name: life360
esp32:
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxx"
ota:
  - platform: esphome
    password: "xxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Life360 Fallback Hotspot"
    password: "KrAzuGFw4YwJ"
# Include custom fonts
font:
  - file: 'fonts/GothamRnd-Book.ttf'
  - file: 'fonts/GothamRnd-Bold.ttf'
    glyphs: [' ', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C',]
    glyphs: [' ', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', ':']
    glyphs: [' ', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9']
    #glyphs: [' ', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'M', 'I', 'N']
# Define colors
# This design is white on black so this is necessary.
color:
  - id: color_black
    red: 0%
    green: 0%
    blue: 0%
    white: 50%
  - id: color_white
    red: 0%
    green: 0%
    blue: 0%
    white: 0%
# Life360 Section
 - platform: homeassistant
   entity_id: binary_sensor.life360_online_willfahy_gmail_com
# Pins for Waveshare ePaper ESP Board
spi:
  clk_pin: GPIO8
  mosi_pin: GPIO10
# Now render everything on the ePaper screen.
display:
  - platform: waveshare_epaper
    cs_pin: GPIO3
    dc_pin: GPIO5
    busy_pin: GPIO4
    reset_pin: GPIO2
    model: 7.50inv2
    update_interval: 1min
    rotation: 0°
    auto_clear_enabled: false
    lambda: |-
      // Weather Section ------------------------------------------------------------------- PLACE NAME
        // TEST it.image(120, 338, id(title_weather));
        it.print(110, 10, id(font_weekday), color_black, TextAlign::TOP_CENTER, "WESTPORT");
      // Life360 Section -------------------------------------------------------------------
captive_portal:
Anyone have a working config for model 7.5in-e? I can’t get anything running.
