jose1711
(Jose Riha)
May 19, 2025, 1:43pm
1
I’ve flashed ESP32C3 with ESPHome and placed it onto Grove Base for XIAO (Grove Shield for Seeed Studio XIAO with embedded battery management chip - Seeed Studio ). All works fine but only if the power is supplied via USB-C port. If I connect the battery nothing happens.
This is what Seeed TechSupport team responded with:
Please remove the line `while(!Serial)` from your code. If this line is
present, the code will keep waiting for the serial connection. This is
why the device can start normally when powered by USB, but cannot start
properly when powered by battery.
I did mention ESPHome to them so I have no idea how the advice can be applied. Any ideas?
Thanks,
jose
Karosm
(Karosm)
May 19, 2025, 2:17pm
3
Drained battery, wrong battery, bad soldering, wrong switch position?
jose1711
(Jose Riha)
May 19, 2025, 10:18pm
4
tested with multiple batteries, two bases, connection checked with multimeter.
Karosm
(Karosm)
May 19, 2025, 10:24pm
5
Define “nothing happens”.
What connections are checked?
Are you using Xiao Esp32-c3 board?
jose1711
(Jose Riha)
May 20, 2025, 7:25pm
6
Turns out that in fact the board was working. It just did not give any visual indication (none of the LEDs were turned on) - a bit misleading.
Karosm
(Karosm)
May 20, 2025, 7:28pm
7
Oh my Lord…
You prefer to waste your battery for indication LED?
tmjpugh
(Tmjpugh)
May 20, 2025, 10:16pm
8
Power led would waste battery but in case you desire
status_led:
pin:
number: GPIOXX
inverted: true
Karosm
(Karosm)
May 20, 2025, 10:48pm
9
What’s the role of status LED in this case…?
tmjpugh
(Tmjpugh)
May 21, 2025, 5:02am
10
To visually show unit is operating
It Is not needed for basic function but useful for troubleshooting
tmjpugh
(Tmjpugh)
May 26, 2025, 2:18pm
11
I have m5 camera with battery. I recently found better way
I use light domain for status led now and for me I had to add switch domain for ON/OFF battery as power source.
you need to remove status_led if using it since you cant resuse the gpio
light:
- platform: binary #per https://github.com/esphome/issues/issues/2828
output: camera_led
output:
- platform: gpio
pin: GPIO2
- platform: wifi_signal
name: $name WiFi Signal
- platform: adc
pin: GPIO38
name: $name Battery Voltage
filters:
multiply: 3.3
switch:
- platform: gpio #per https://github.com/esphome/issues/issues/2828
pin: GPIO33
name: $name Battery State
