I’ve started noticing some performance issues with my z-wave network these last few days. In particular, one GE 14291 switch stopped sending instant updates to HA when turned on/off (though it would respond to commands from HA). So I removed the switch and reset it - that was a process - and it seems to be working fine again.
However, I’ve now noticed some big lags in my system which indicates heavy traffic. I checked the OZW logs and I noticed a GE 14294 dimmer being polled every few minutes. Here is a log excerpt from 4:30 am:
2018-03-30 04:35:51.096 Detail, Node012, Polling: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (poll queue has 0 messages)
2018-03-30 04:35:51.096 Detail, Node012, Queuing (Poll) SwitchMultilevelCmd_Get (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x26, 0x02, 0x25, 0x84, 0x6e
2018-03-30 04:35:51.096 Info, Node012, Sending (Poll) message (Callback ID=0x84, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x26, 0x02, 0x25, 0x84, 0x6e
2018-03-30 04:35:51.443 Detail, Node012, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-30 04:35:51.443 Detail, Node012, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-30 04:35:51.655 Detail, Node012, Received: 0x01, 0x07, 0x00, 0x13, 0x84, 0x00, 0x00, 0x16, 0x79
2018-03-30 04:35:51.655 Detail, Node012, ZW_SEND_DATA Request with callback ID 0x84 received (expected 0x84)
2018-03-30 04:35:51.655 Info, Node012, Request RTT 558 Average Request RTT 522
2018-03-30 04:35:51.655 Detail, Expected callbackId was received
2018-03-30 04:35:51.794 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xd8
2018-03-30 04:35:51.794 Info, Node012, Response RTT 697 Average Response RTT 660
2018-03-30 04:35:51.794 Info, Node012, Received SwitchMultiLevel report: level=0
2018-03-30 04:35:51.794 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2018-03-30 04:35:51.794 Detail, Node012, Changes to this value are not verified
2018-03-30 04:35:51.794 Detail, Node012, Expected reply and command class was received
2018-03-30 04:35:51.794 Detail, Node012, Message transaction complete
2018-03-30 04:35:51.794 Detail, Node012, Removing current message
2018-03-30 04:35:51.794 Detail, Node012, Notification: ValueChanged
I only have polling setup for one of my switches on 40+ device network and it is an EATON dimmer that I had to use and the polling_intensity is set to 15.
Does anyone have any suggestions? it seems odd that this device is suddenly starting to flood the network and I vaguely recall having the same issue with another dimmer a few months ago - I think a reset and re-add fixed it.
Would adding a custom entry in the zwave_device_config.yaml with polling_intensity: 0 help resolve this issue? I’m just trying to figure out first what causes this random issue and second, the quickest fix.
Thanks for the help,
Will
