As the title, is there a way to see the countdown of a trigger?
For example, my automation says if there is no movement within 50 seconds then start an action. I would like to display that countdown in a card
I don’t think so. You could use a countdown timer in another automation with the same trigger, but then there’s the problem of stopping the timer if the first automation doesn’t trigger.
