Hi all, I have just added a Blink camera with the basic configuration as described in https://home-assistant.io/components/blink/ I want to be able to setup an alarm system which arms the camera when nobody is home, and I guess I need a https://home-assistant.io/components/switch.template/ I would also like to be able to manually set the alarm, over-riding the presence trigger, and also be able to mute the alarm for 1 hour. I looked through the example configs but didn’t find anything matching these requirements. Any advice greatly appreciated
