Seeking Advice on Sleep-Focused Lighting with Home Assistant
Hello everyone,
Interested in enhancing our sleep routine. At first, I imagined simulating sunlight in the morning and moonlight at night using my TPLink Kasa LED strips. It could be pretty simple, just create a bunch of scenes that are say a light purple dimmed (30%,20%,10% etc) and then make automations based on time that run on the led strip…I’ve been encountering some challenges with the integration though. The LEDs frequently drop out of Home Assistant unexpectedly, which will disrupt my planned lighting sequences.
I’m curious to know if others have a reliable setup in this context. What hardware are you using for your lighting automation? Are there alternative smart devices or brands that have proven to be more reliable than TP-Link Kasa?
If anyone is willing to share their automation configurations in YAML, I would greatly appreciate it. Seeing examples would be awesome.
Thanks!
I currently use HUE bulbs for the bedside lamps and my lounge room corner lamp and a HUE led strip at the top edge of my bathroom since my main light is just pure white LED and has the exhaust fan tied to it’s on and off state.
These HUE devices are then linked to the Circadian custom intergration.
I then use a aqara leak sensor set to occupancy mode and use a pressure mat connected to its screws to trigger states when I am in or out of bed (added benefit of letting me track my sleep hours).
These states then trigger to turn off all the lights in the home, disable motion sensor automation’s, turn on my air purifier to help me sleep, put the PC monitors to sleep using hass agent mqtt command and if my alarm is enabled on my phone via hassalarm state update push and I am have been in bed for more than 5min and the alarm is set between 6a and 12p on a weekday then it toggles the on state for the switch to use the bedroom HUE bulbs to turn on when the alarm goes off which is using the circadian system to apply the correct color and temperature settings automatically.
alias: Bed Occupancy Automations
description: ""
  - type: not_locked
    platform: device
    device_id:
    entity_id:
    domain: binary_sensor
    id: Latch State - Unlocked
  - type: occupied
    platform: device
    device_id:
    entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 31
    id: Occupied - 30s
  - type: occupied
    platform: device
    device_id:
    entity_id:
    for:
      hours: 0
      minutes: 5
      seconds: 0
    id: Occupied - 5min
  - type: not_occupied
    platform: device
    device_id:
    entity_id:
    for:
      hours: 0
      minutes: 0
      seconds: 11
    id: Unoccupied - 10s
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Occupied - 30s
        sequence:
          - service: automation.turn_off
            metadata: {}
              stop_actions: true
              entity_id:
                - automation.bedside_lamps_toggle
                - automation.bathroom_humidity_management
          - service: light.turn_off
            metadata: {}
            data: {}
              area_id:
                - bathroom
                - bedroom
                - kitchen
                - living_room
          - device_id:
            domain: button
            entity_id:
            type: press
      - conditions:
            id:
              - Occupied - 5min
        sequence:
              entity_id: input_boolean.alarm_toggle
            data: {}
      - conditions:
            id:
              - Unoccupied - 10s
        sequence:
          - service: automation.turn_on
            data: {}
              entity_id:
          - service: input_boolean.turn_off
            metadata: {}
            data: {}
      - conditions:
            id:
              - Occupied - 30s
          - condition: and
            conditions:
                id:
                  - Latch State - Unlocked
        sequence:
          - service: notify.mobile_app_rkphone
              title: Door Lock
                notification_icon: mdi:lock-smart
                color: red
              message: Front Door Nightlatch is unlocked!
mode: single
alias: Alarm Clock
description: ""
  - platform: time
    at: input_datetime.next_alarm
condition:
  - condition: state
    state: "on"
    enabled: true
  - condition: and
    conditions:
      - condition: time
        after: "06:00:00"
        before: "12:00:00"
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
  - service: light.turn_on
      label_id: bedside_lamps
      transition: 60
mode: single
alias: Alarm Clock Toggle
description: ""
  - platform: state
    entity_id:
      - input_boolean.alarm_toggle
    to: "on"
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
            id:
              - Alarm on
        sequence:
            metadata: {}
            data: {}
              entity_id: automation.alarm_clock
      - conditions:
            id:
              - Alarm off
        sequence:
              stop_actions: true
mode: single
This should get you and others pointed in the right direction for your setup needs based on what I have setup so far.
