I have Aeotec Zwave gen5 USB stick already integrated in my Z-Wave
How can I get my existing network key so I can migrate to Z-WaveJS?
Thank you.
Did you set up the original zwave in yaml or thru the UI?
if in yaml then you might have an options.xml file in your config directory that contains the key. If that file is not there you may have to do a search on the entire host machine for it.
if you installed thru the UI then it is stored in the hidden /.storage/core.config_entries file.
I had it installed through UI, so I found it in my backup files.
Thank you.
