Seeking help configuring LSC power plug for Local Tuya
I just bought a LSC power plug, and setup local tuya on my HA.
No problem adding the power plug, and turning it on/off.
But I noticed a lot of extra’s, and don’t know how to access these.
After adding I get ’ Configure entity’
The first ’ ID’ I keep default (1(value False), this seems to work for on/off
But below that is ’ Current ', ’ Current Consumtion ’ and ’ Voltage ’ !? what can I do with them?
When I look in the Toya IoT platform at ’ Get Device Specification ’
I see this information.
Who can help, what all is possible with this plug? looks like more than just on/off
  "result": {
    "category": "cz",
    "functions": [
        "code": "switch_1",
        "lang_config": {
          "false": "OFF",
          "true": "ON"
        "name": "Switch 1",
        "type": "Boolean",
        "values": "{}"
        "code": "countdown_1",
        "lang_config": {
          "unit": "s"
        "name": "Countdown 1",
        "type": "Integer",
        "values": "{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1}"
        "code": "relay_status",
        "lang_config": {
          "last": "Remember last status",
          "power_off": "Off",
          "power_on": "ON"
        "name": "relay status",
        "type": "Enum",
        "values": "{\"range\":[\"power_off\",\"power_on\",\"last\"]}"
    "status": [
        "code": "switch_1",
        "lang_config": {
          "false": "OFF",
          "true": "ON"
        "name": "Switch 1",
        "type": "Boolean",
        "values": "{}"
        "lang_config": {
          "unit": "s"
        "type": "Integer",
        "lang_config": {
          "power_off": "Off",
          "power_on": "ON"
        "type": "Enum",
  "success": true,
  "t": 1665132598370,
  "tid": "05c0b7bf461d11ed9fa122dacb9008b9"
Try this
I don’t think the LSC plugs support power monitoring.
