Seeking help with Yaml automation (data_template)
Hi
I am unable to get this working. The template renders well but the service call does not.
    service: climate.set_temperature
    data_template:
      entity_id: climate.bedroom_ac
      hvac_mode: "cool"
      temperature: {{states('sensor.bedroom_avg_temp') |int + 2}}
      target_temp_high: {{states('sensor.bedroom_avg_temp') |int + 4}}
      target_temp_low: {{ states('sensor.bedroom_avg_temp')}}
What am I doing wrong? Any tips will be quite helpful. Struggling with it since last evening. Please help
Put quotation marks around your templates
Ignore the funky indentations, I’m on my phone :roll_eyes:
Thanks @jivesinger . I did try this in one of the iterations but I get the following error when I call the service from developers tab. It validates the Configuration though.
Failed to call service climate/set_temperature. must contain at least one of temperature, target_temp_high, target_temp_low.
The answer to your problem may be here…
You may have to break down your action in to several service calls.
Fair point… I broke the service call and just gave the temperature with the template (also removed hvac_mode). Still the service refuses to be called.
Maybe data_template does not work with this service.
