Segfault when starting HA in wmiir
When I start HA I see this message in the console:
Not sure why wmiir is running, it’s a NUC with pve, and HA is running in a VM, so no windows anywhere?
Is it Home Assistant OS or Home Assistant Core?
I get the same, as you can see, it halts for 68 seconds afterwards:
Running a VM in VirtualBox on Windows 10
Home Assistant OS, HassOS 4.11
All works OK, is it something to be worried about ?
[   48.665624] wmiir[7624]: segfault at 0 ip 00007f89314f9206 sp 00007ffc7a748c68 error 4 in libc-2.28.so[7f8931483000+148000]
[   48.672698] Code: 0f 1f 40 00 66 0f ef c0 66 0f ef c9 66 0f ef d2 66 0f ef db 48 89 f8 48 89 f9 48 81 e1 ff 0f 00 00 48 81 f9 cf 0f 00 00 77 6a <f3> 0f 6f 20 66 0f 74 e0 66 0f d7 d4 85 d2 74 04 0f bc c2 c3 48 83
[   48.683617] audit: type=1701 audit(1595348011.569:206): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=7624 comm="wmiir" exe="/usr/bin/wmiir" sig=11 res=1
[  116.796176] hassio: port 11(vethe0de6e7) entered blocking state
Has anyone resolved this problem? i have a similar situation on proxmox. Any way to speed up loading ha skipping wmiir?
Not that I’m aware of, I guess an issue on github…
Experiencing this too, was trying to restore from my pi4 snapshot to nuc8i3beh running proxmox. The segfault on wmiirr is shown as soon as I power up Deconz add-on with conbee 2 stick attached (passthrough). Note that nortek huzbzb-1 is working as z-wave stick though. I already tried using with or without usb2 extension and it’s the same.
EDIT: same with HASSOS supported installation and latest deconz add-on from scratch, this issue occurs.
EDIT2: segfault usually occurs when you try to map the USB on deconz addon via /dev/serial/by-id. However, the last time I tried it, it shows the segfault but it didn’t crash the VM, I couldn’t enter the click the conbee stick on phoscon though. /dev/ttyACM0 works well and the segfault doesn’t appear. WIl try to migrate again my prod HA tomorrow.
Ok, so I got this running for 17 days and upgraded my hassos to 4.13, able to boot but then again, it freezes. I thought it was the update that killed the VM. However, tried to remove the conbee 2 stick again so deconz will not load anything, so voila, HA booted.
EDIT: working again after downgrading the OS to 4.12
EDIT: opened github issue 870
I am using Esxi and I have /dev/ttyACM0 in deconz config.
[Tue Nov 17 12:55:47 2020] hassio: port 9(vethe2a9e29) entered disabled state
[Tue Nov 17 12:55:47 2020] veth6a62d6b: renamed from eth0
[Tue Nov 17 12:55:47 2020] device vethe2a9e29 left promiscuous mode
[Tue Nov 17 12:57:34 2020] usb 2-2.1: new full-speed USB device number 36 using uhci_hcd
[Tue Nov 17 12:57:35 2020] usb 2-2.1: New USB device found, idVendor=1cf1, idProduct=0030
[Tue Nov 17 12:57:35 2020] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Tue Nov 17 12:57:35 2020] usb 2-2.1: Product: ConBee II
[Tue Nov 17 12:57:35 2020] usb 2-2.1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[Tue Nov 17 12:57:35 2020] usb 2-2.1: SerialNumber: DE2131280
[Tue Nov 17 12:57:35 2020] cdc_acm 2-2.1:1.0: ttyACM0: USB ACM device
[Tue Nov 17 12:57:39 2020] usb 2-2.1: USB disconnect, device number 36
[Tue Nov 17 12:57:39 2020] usb 2-2.1: new full-speed USB device number 37 using uhci_hcd
[Tue Nov 17 12:57:40 2020] usb 2-2.1: New USB device found, idVendor=1cf1, idProduct=0030
[Tue Nov 17 12:57:40 2020] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Tue Nov 17 12:57:40 2020] usb 2-2.1: Product: ConBee II
[Tue Nov 17 12:57:40 2020] usb 2-2.1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[Tue Nov 17 12:57:40 2020] usb 2-2.1: SerialNumber: DE2131280
[Tue Nov 17 12:57:40 2020] cdc_acm 2-2.1:1.0: ttyACM0: USB ACM device
[Tue Nov 17 12:58:05 2020] hassio: port 9(vetha866473) entered blocking state
[Tue Nov 17 12:58:05 2020] hassio: port 9(vetha866473) entered disabled state
[Tue Nov 17 12:58:05 2020] device vetha866473 entered promiscuous mode
[Tue Nov 17 12:58:05 2020] IPv6: ADDRCONF(NETDEV_UP): vetha866473: link is not ready
[Tue Nov 17 12:58:06 2020] eth0: renamed from veth2e1ee99
[Tue Nov 17 12:58:06 2020] IPv6: ADDRCONF(NETDEV_CHANGE): vetha866473: link becomes ready
[Tue Nov 17 12:58:06 2020] hassio: port 9(vetha866473) entered blocking state
[Tue Nov 17 12:58:06 2020] hassio: port 9(vetha866473) entered forwarding state
[Tue Nov 17 12:58:08 2020] wmiir[26433]: segfault at 0 ip 00007f9852df2206 sp 00007ffe0d708ba8 error 4 in libc-2.28.so[7f9852d7c000+148000]
Could you modify the logfile to have just the wmiir then the logline after it. It warrants an issue on github, as I still see the wmiir problem.
I don’t see any crashes, and I don’t loose the USB stick and deconz.
I am getting segfault also. I was losing the sticks, but now they stopped dropping/adding (every 120 seconds)
Then it pauses for about 100 seconds before continuning.
