SEH utnserver Pro
Hi all,
I have a HA installation running in a virtual machine on my Synology NAS in my home. This works perfectly well. I now would like to integrate my blinds. I therefore have purchased the Becker Centronic Plus USB-Stick.
Because my Synology running the VM with HA is in the basement, far away from the window-shutters, I came up with the idea to use an USB to IP solution. For example, a UTnServer Pro from SEH.
I assume that in order to run this, I must install drivers. Is this possible in my case? Is there anyone who has experience with USB to IP in HA?
Regards,
R.
I’m in exactly the same situation and have also been looking into this, also with the utnserver pro.
I figured it might actually work with Docker as well, but I am not sure if you can then forward the “fake” USB port still to the VM.
Have you already got a solution?
Anybody else with ideas?
