Select/activate Hue scenes in new v2 Api setup
no. it’s just a bit of yaml :wink:
To someone new, it is a lot and not super clear what needs to be done to use it.
I tried asking ChatGPT to infer the instructions from this post and it also failed :smile: ).
I’m trying to get this working as a package, as suggest by @Mariusthvdb
It seems to validate in Studio code, but when checking config yaml I get the error:
Configuration invalid!
 expected dict for dictionary value @ data['packages']['hue_scene_selector']['type']
Can anyone help me?
I believe you have the wrong information in that file. That’s the configuration for an Entities card with several custom card enhancements.
What belongs in that file is shown in the second half of Mariusthvdb’s post (the part describing the “necessary back-end code”).
Thanks, I got it working!
  1. place the backend YAML; either in a package or in each appropriate config file
  2. place the frontend YAML in a custom lovelace card
  3. run the auto populate automation(s)
Can you go in a bit more detail? If appreciate it!
I get the following trying to recreate your steps above:
fwiw, Ive since then changed my backend code a bit:
# Automations
automation:
  - id: auto_populate_hue_group_input_select
    mode: restart
      platform: event
      event_type: delayed_homeassistant_start
      service: input_select.set_options
        entity_id: input_select.hue_group
        options: >
          {{expand(integration_entities('Philips Hue 1'),
                   integration_entities('Philips Hue 3'))
            |selectattr('attributes.is_hue_group','defined')
            |selectattr('attributes.is_hue_group','eq',true)
            |map(attribute='name')|list}}
  - id: auto_populate_hue_dynamic_scene_input_select
    mode: restart
      platform: state
        entity_id: input_select.hue_dynamic_scene
        options: >
          {% set hue_group = states('input_select.hue_group') %}
          {{states.scene
            |selectattr('attributes.group_name','defined')
            |selectattr('attributes.group_name','eq',hue_group)
            |selectattr('attributes.is_dynamic','eq',true)
remember this is inside a package. meaning, if you have another hierarchy/organization of files you should adapt the main keys config keys (automation:, or the - alias)
I captured all the scene gallery icons from the hue app here:
https://github.com/mattmon/hue-scene-icons
Prerequisites:
  • A hue bridge (I use diyHue). Must have at least one room configured with a scene saved to the bridge.
  • HA Hue integration connected to that bridge. Hue scenes should already exist within your HA instance.
  • These dependencies from HACS: card-mod, fold-entity-row. auto-entities, template-entity-row
Installation
  1. Add the following to your configuration.yaml:
homeassistant:
  packages:
    hue_scene_selector: !include hue_scene_selector.yaml
  1. Create a new file named hue-scene-selector.yaml, with the following contents:
input_select:
# need at least 1 option for the config check, which will be overwritten during startup
  hue_group:
    name: Select Hue group
    options:
      - Alarm
#    initial: Alarm
  hue_dynamic_scene:
    name: Hue Dynamic scene
    options:
      - 'Alarm - Tyrell'
input_number:
  hue_dynamic_scene_speed:
    name: Hue scene speed
    min: 0
    max: 100
    step: 10
  hue_dynamic_scene_brightness:
    name: Hue scene brightness
    min: 0
    max: 255
    step: 10
template:
  binary_sensor:
    - unique_id: selected_hue_group_active_scene
      name: Selected Hue group active scene
      state: >
        {% set select = states('input_select.hue_group')|slugify %}
        {% set group ='light.' + select %}
        {{is_state_attr(group,'dynamics',true)}}
    - unique_id: selected_hue_group_has_active_scenes_available
      name: Selected Hue group has active scenes available
      state: >
          {{states.scene
            |selectattr('attributes.is_dynamic','eq',true)|list|length != 0}}
    - unique_id: hue_groups_dynamic_scening
      name: Hue groups dynamic scening
      state: >
        {{states.light|selectattr('attributes.dynamics','eq',true)|list|length != 0}}
#        {% set select = states('input_select.hue_group') %}
#        {% set group = states.light
#          |selectattr('attributes.friendly_name','eq',select)
#          |map(attribute='entity_id')|join %}
#        {{is_state_attr(group,'dynamics',true)}}
script:
  activate_hue_dynamic_scene:
    alias: Activate Hue dynamic scene
    mode: restart
    icon: mdi:power
    sequence:
      - condition: >
          {{is_state('binary_sensor.selected_hue_group_active_scene','off')}}
# first record current state of lights in the selected group
      - service: scene.create
          scene_id: before_dynamic_scene
          snapshot_entities:
              {{group}}
      - service: hue.activate_scene
          dynamic: true
          speed: >
            {{states('input_number.hue_dynamic_scene_speed')|int}}
          brightness: >
            {{states('input_number.hue_dynamic_scene_brightness')|int}}
          entity_id: >
            {% set select = states('input_select.hue_dynamic_scene')|slugify %}
            {{'scene.' + select}}
#            {% set select = states('input_select.hue_dynamic_scene')%}
#            {{states.scene
#             |map(attribute='entity_id')|join}}
  deactivate_hue_dynamic_scene:
    alias: Deactivate Hue dynamic scene
    mode: restart
    icon: mdi:power-off
    sequence:
      - condition: >
          {{is_state('binary_sensor.selected_hue_group_active_scene','on')}}
          dynamic: false
          entity_id: >
# reset the lights to the state before the dynamic scene activation
      - service: scene.turn_on
          entity_id: scene.before_dynamic_scene
automation:
  - alias: Auto populate Hue group input select
    id: Auto populate Hue group input select
    mode: restart
      platform: event
        options: >
          {{states.light
  - alias: Auto populate Hue dynamic scene input select
    id: Auto populate Hue dynamic scene input select
    mode: restart
      - platform: event
      - platform: state
        options: >
          {{states.scene
  1. Add a card to any dashboard, choose the “Manual” card type with the following contents:
type: entities
title: Set Hue scenes
show_header_toggle: false
card_mod:
  style: |
    .card-header {
      background-color: var(--background-color-off);
      color: var(--text-color-off);
      padding-top: 0px;
      padding-bottom: 0px;
      margin: 0px 0px 16px 0px;
    ha-card {
      margin: 0px 0px 16px 0px; /* create space before next card in view*/
entities:
  - input_select.hue_group
  - type: custom:fold-entity-row
    card_mod:
      style: |
        #measure {
          max-height: 300px;
          overflow-x: hidden;
          overflow-y: scroll;
    head:
      type: section
      label: Regular scenes
      card_mod:
        style: |
          .label {
            margin-left: 0px;
    padding: 0
    no_animation: true
    entities:
      - type: custom:auto-entities
        card:
          type: entities
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                margin: 0px -16px;
        show_empty: false
        filter:
          template: |
            {% set ns = namespace(scenes=[]) %}
            {%- for s in states.scene
              if hue_group == s.attributes.group_name and
                  s.attributes.is_dynamic != true %}
                {% set ns.scenes = ns.scenes + [{'entity':s.entity_id,
                  'name': s.object_id.split(hue_group|slugify +'_')[1]|capitalize|replace('_',' ') }] %}
            {%- endfor %}
            {{ns.scenes}}
  - type: conditional
    conditions:
      - entity: binary_sensor.selected_hue_group_has_active_scenes_available
        state: 'on'
    row:
      head:
        type: section
        label: Dynamic scenes
        card_mod:
          style: |
            .label {
              margin-left: 0px;
      padding: 0
      no_animation: true
      entities:
          card:
            type: entities
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                  margin: 0px -16px;
                .card-content {
                   max-height: 250px;
                   overflow-y: scroll;
          filter:
            template: |
                    s.attributes.is_dynamic == true %}
              {%- endfor %}
              {{ns.scenes}}
        - input_select.hue_dynamic_scene
        - input_number.hue_dynamic_scene_speed
        - input_number.hue_dynamic_scene_brightness
        - type: conditional
          conditions:
            - entity: binary_sensor.selected_hue_group_active_scene
              state: 'off'
          row:
            entity: script.activate_hue_dynamic_scene
            icon: mdi:play
            action_name: play
        - type: conditional
          conditions:
              state: 'on'
          row:
            entity: script.deactivate_hue_dynamic_scene
            icon: mdi:stop
            action_name: stop
        - type: conditional
          conditions:
            - entity: binary_sensor.hue_groups_dynamic_scening
              state: 'on'
          row:
            head:
              type: section
              label: Currently scening group
              card_mod:
                style: |
                  .label {
                    margin-left: 0px;
            padding: 0
            no_animation: true
            entities:
                card:
                  type: entities
                  card_mod:
                    style: |
                      ha-card {
                        box-shadow: none;
                        margin: 0px -16px;
                show_empty: false
                filter:
                  include:
                    - attributes:
                        dynamics: true
        - type: conditional
          conditions:
              state: 'on'
          row:
            head:
              type: section
              label: Currently scening lights
              card_mod:
                style: |
                  .label {
                    margin-left: 0px;
            padding: 0
            no_animation: true
            entities:
                card:
                  type: entities
                  card_mod:
                    style: |
                      ha-card {
                        box-shadow: none;
                        margin: 0px -16px;
                show_empty: false
                filter:
                  include:
                    - attributes:
                        dynamics: dynamic_palette
  - type: custom:template-entity-row
    entity: |
      light.{{states('input_select.hue_group')|slugify}}
    secondary: >
      {% set x = ['unknown','unavailable'] %} {% if
      states('input_select.hue_group') not in x %} {% set object =
      states('input_select.hue_group')|slugify %} {% set group = 'light.' +
      object %}
        {% set bri = state_attr(group,'brightness') %}
        {% set rgb = state_attr(group,'rgb_color') %}
        {% if states(group) == 'on' %} Bri: {{bri}}, Rgb: {{rgb}}
        {% else %} Off
        {% endif %} since {{relative_time(states[group].last_changed) if (states[group]
          and states[group].last_changed not in x) else 'Initializing....'}}
      {% else %} Not yet set {% endif %}
    toggle: true
    head:
      type: section
      label: Automations
      card_mod:
        style: |
          .label {
            margin-left: 0px;
    padding: 0
    no_animation: true
    entities:
      - entity: automation.auto_populate_hue_group_input_select
        secondary_info: last-triggered
      - entity: automation.auto_populate_hue_dynamic_scene_input_select
  1. Go to Settings → Automations and run the two automations to populate the front end lists.
If you want the scene icons from the hue app like in this post by @Mariusthvdb, then:
  1. Create a new directory within www named “hue_scene_icons”
  2. Download the scene icons and put them in there
  3. Append the following to your hue_scene_selector.yaml:
homeassistant:
  customize_glob:
    scene.*adrift:
      entity_picture: /local/hue_scene_icons/adrift.png
    scene.*amber_bloom:
      entity_picture: /local/hue_scene_icons/amber_bloom.png
    scene.*amethyst_valley:
      entity_picture: /local/hue_scene_icons/amethyst_valley.png
    scene.*arctic_aurora:
      entity_picture: /local/hue_scene_icons/arctic_aurora.png
    scene.*autumn_gold:
      entity_picture: /local/hue_scene_icons/autumn_gold.png
    scene.*beginnings:
      entity_picture: /local/hue_scene_icons/beginnings.png
    scene.*blood_moon:
      entity_picture: /local/hue_scene_icons/blood_moon.png
    scene.*blossom:
      entity_picture: /local/hue_scene_icons/blossom.png
    scene.*blue_lagoon:
      entity_picture: /local/hue_scene_icons/blue_lagoon.png
    scene.*blue_planet:
      entity_picture: /local/hue_scene_icons/blue_planet.png
    scene.*bright:
      entity_picture: /local/hue_scene_icons/bright.png
    scene.*cancun:
      entity_picture: /local/hue_scene_icons/cancun.png
    scene.*chinatown:
      entity_picture: /local/hue_scene_icons/chinatown.png
    scene.*concentrate:
      entity_picture: /local/hue_scene_icons/concentrate.png
    scene.*cool_bright:
      entity_picture: /local/hue_scene_icons/cool_bright.png
    scene.*crocus:
      entity_picture: /local/hue_scene_icons/crocus.png
    scene.*dimmed:
      entity_picture: /local/hue_scene_icons/dimmed.png
    scene.*disturbia:
      entity_picture: /local/hue_scene_icons/disturbia.png
    scene.*dreamy_dusk:
      entity_picture: /local/hue_scene_icons/dreamy_dusk.png
    scene.*emerald_flutter:
      entity_picture: /local/hue_scene_icons/emerald_flutter.png
    scene.*emerald_isle:
      entity_picture: /local/hue_scene_icons/emerald_isle.png
    scene.*energize:
      entity_picture: /local/hue_scene_icons/energize.png
    scene.*fairfax:
      entity_picture: /local/hue_scene_icons/fairfax.png
    scene.*first_light:
      entity_picture: /local/hue_scene_icons/first_light.png
    scene.*forest_adventure:
      entity_picture: /local/hue_scene_icons/forest_adventure.png
    scene.*frosty_dawn:
      entity_picture: /local/hue_scene_icons/frosty_dawn.png
    scene.*galaxy:
      entity_picture: /local/hue_scene_icons/galaxy.png
    scene.*golden_pond:
      entity_picture: /local/hue_scene_icons/golden_pond.png
    scene.*hal:
      entity_picture: /local/hue_scene_icons/hal.png
    scene.*hazy_days:
      entity_picture: /local/hue_scene_icons/hazy_days.png
    scene.*honolulu:
      entity_picture: /local/hue_scene_icons/honolulu.png
    scene.*horizon:
      entity_picture: /local/hue_scene_icons/horizon.png
    scene.*ibiza:
      entity_picture: /local/hue_scene_icons/ibiza.png
    scene.*lake_mist:
      entity_picture: /local/hue_scene_icons/lake_mist.png
    scene.*lake_placid:
      entity_picture: /local/hue_scene_icons/lake_placid.png
    scene.*lily:
      entity_picture: /local/hue_scene_icons/lily.png
    scene.*magneto:
      entity_picture: /local/hue_scene_icons/magento.png
    scene.*majestic_morning:
      entity_picture: /local/hue_scene_icons/majestic_morning.png
    scene.*memento:
      entity_picture: /local/hue_scene_icons/memento.png
    scene.*meriete:
      entity_picture: /local/hue_scene_icons/meriete.png
    scene.*miami:
      entity_picture: /local/hue_scene_icons/miami.png
    scene.*midsummer_sun:
      entity_picture: /local/hue_scene_icons/midsummer_sun.png
    scene.*midwinter:
      entity_picture: /local/hue_scene_icons/midwinter.png
    scene.*misty_ridge:
      entity_picture: /local/hue_scene_icons/misty_ridge.png
    scene.*moonlight:
      entity_picture: /local/hue_scene_icons/moonlight.png
    scene.*motown:
      entity_picture: /local/hue_scene_icons/motown.png
    scene.*mountain_breeze:
      entity_picture: /local/hue_scene_icons/mountain_breeze.png
    scene.*narcissa:
      entity_picture: /local/hue_scene_icons/narcissa.png
    scene.*nebula:
      entity_picture: /local/hue_scene_icons/nebula.png
    scene.*nightlight:
      entity_picture: /local/hue_scene_icons/nightlight.png
    scene.*ocean_dawn:
      entity_picture: /local/hue_scene_icons/ocean_dawn.png
    scene.*orange_fields:
      entity_picture: /local/hue_scene_icons/orange_fields.png
    scene.*osaka:
      entity_picture: /local/hue_scene_icons/osaka.png
    scene.*painted_sky:
      entity_picture: /local/hue_scene_icons/painted_sky.png
    scene.*palm_beach:
      entity_picture: /local/hue_scene_icons/palm_beach.png
    scene.*pensive:
      entity_picture: /local/hue_scene_icons/pensive.png
    scene.*precious:
      entity_picture: /local/hue_scene_icons/precious.png
    scene.*read:
      entity_picture: /local/hue_scene_icons/read.png
    scene.*relax:
      entity_picture: /local/hue_scene_icons/relax.png
    scene.*resplendant:
      entity_picture: /local/hue_scene_icons/resplendant.png
    scene.*rest:
      entity_picture: /local/hue_scene_icons/rest.png
    scene.*rio:
      entity_picture: /local/hue_scene_icons/rio.png
    scene.*rolling_hills:
      entity_picture: /local/hue_scene_icons/rolling_hills.png
    scene.*ruby_glow:
      entity_picture: /local/hue_scene_icons/ruby_glow.png
    scene.*savanna_sunset:
      entity_picture: /local/hue_scene_icons/savanna_sunset.png
    scene.*scarlet_dream:
      entity_picture: /local/hue_scene_icons/scarlet_dream.png
    scene.*soho:
      entity_picture: /local/hue_scene_icons/soho.png
    scene.*spring_blossom:
      entity_picture: /local/hue_scene_icons/spring_blossom.png
    scene.*spring_lake:
      entity_picture: /local/hue_scene_icons/spring_lake.png
    scene.*starlight:
      entity_picture: /local/hue_scene_icons/starlight.png
    scene.*still_waters:
      entity_picture: /local/hue_scene_icons/still_waters.png
    scene.*sunday_morning:
      entity_picture: /local/hue_scene_icons/sunday_morning.png
    scene.*sundown:
      entity_picture: /local/hue_scene_icons/sundown.png
    scene.*sunflare:
      entity_picture: /local/hue_scene_icons/sunflare.png
    scene.*tokyo:
      entity_picture: /local/hue_scene_icons/tokyo.png
    scene.*tropical_twilight:
      entity_picture: /local/hue_scene_icons/tropical_twilight.png
    scene.*tyrell:
      entity_picture: /local/hue_scene_icons/tyrell.png
    scene.*valley_dawn:
      entity_picture: /local/hue_scene_icons/valley_dawn.png
    scene.*vapor_wave:
      entity_picture: /local/hue_scene_icons/vapor_wave.png
    scene.*warm_embrace:
      entity_picture: /local/hue_scene_icons/warm_embrace.png
    scene.*winter_beauty:
      entity_picture: /local/hue_scene_icons/winter_beauty.png
    scene.*winter_mountain:
      entity_picture: /local/hue_scene_icons/winter_mountain.png
Thank you so much for the tutorial and thanks to the original creator. More people need to know about this, works well and will finally allow me to ditch the Hue app.
Indeed, thanks to @Mariusthvdb for all his efforts in putting this code together.
Building on his work, I mashed up a scene selector suited for the T6E android panels that I use around the house:
Screencast from 2023-09-17 15-05-30
It’s pretty ugly, don’t copy/paste this, use it as a basis to make your own.
Here’s the gist of it:
type: custom:swipe-card
parameters:
  shortSwipes: false
  pagination:
    el: .swiper-scrollbar
  spaceBetween: 10
  effect: coverflow
  coverflowEffect:
    rotate: 30
    slideShadows: false
cards:
    card:
      type: grid
      columns: 4
    card_param: cards
    filter:
      template: |-
        {% set hue_group = 'guestbed1' %}
        {% for s in states.scene
              s.attributes.is_dynamic == true -%}
          {% if loop.index0 >= 0 and loop.index0 < 12 -%}
              'type': 'custom:button-card',
              'entity': s.entity_id,
              'aspect_ratio': 1/1,
              'show_state': false,
              'show_entity_picture': true,
              'name': s.object_id.split(hue_group|slugify +'_')[1]|capitalize|replace('_',' '),
          {%- endif %}
        {%- endfor %}
Then you’d repeat the auto-entities section, adjusting as necessary for your setup. Would probably be better suited to a macro.
I tried to do this with just the swiper card and one auto-entities template, but swiper card doesn’t seem to handle the grid capabilities of swiper.js.
Couldn’t ever figure out how to get this to work. I was able to find an alternative in homebridge.
This is great work. Well done @mattmon and @Mariusthvdb. If it ever makes sense to merge the hass-hue-icons repo into this and create a one stop shop, please let me know. Life hasn’t afforded me the time to be as hands on as I’d like with this recently.
Hey all! I have tried to get this to work and I think I’m on the right path but missing something. I have created the hue_scene_selector.yaml file, uploaded the scene icons to /www/hue_scene_icons , appended the yaml file with the scene icon locations. After that I ran the 2 generated automations. But after no luck and rebooting HA, my scene icons are just blank:
Any suggestions?
you should define what ‘this’ is…
my original setup, or the piggyback guideline by @mattmon ?
If the latter , please open a another topic on the matter, because it is only confusing to mix the two here.
if you want your scenes to show an image, all you have to do is customize_glob like I posted in one of the first posts
Looks like you’re almost there.
Can you isolate the icon problem to either the path or configuration?
Check in your web console and see if HA is trying to load the icons.
What do you see?
I’d like to think that my guide to installing your code makes thing LESS confusing, haha :stuck_out_tongue:
Though, the swiper UI modification, while building upon your work, definitely muddies the water a bit.
If you’re just getting started with this, start with running @Mariusthvdb’s code. Once you understand that, my example mod will be much more helpful to you.
tbh, you’re contradicting yourself here, but I’lll leave it be…
Not sure if you should guide people into using the buggy and neglected Swiper card at all really, it has proven to be rather a tricky thing in various configs.
I’ll ask again, if you want your own instructions to be the center of discussion, please open a separate thread, because now, you’re really confusing things, and not helping anyone.
in fact the only thing of real importance was understanding the various templates and how they get instantiated.
the rest is mere frontend sparkle, and to each their own.
Marius,
I appreciate your work with this as it’s great for any Hue user, but the guide you made was not helpful in getting this up and working, especially someone with less HA knowledge like myself at that point a few months ago. mattmon’s guide was key in me getting it working. I’m currently using his original guide that he posted on September 5th.
