I want to create a script which does some stuff and then changes my ecobee’s preset mode. What I have (below) works fine, but I don’t want to hard-code the list of presets. This list is available in a preset_modes (note plural) attribute of the Ecobee climate entity… but it doesn’t seem to work to provide {{ state_attr("climate.top_floor","preset_modes") }} as a template to selector: select: options: instead of the typed-out list.
Is this possible in some way?
alias: "Ecobee: Change Preset with Timer"
description: >-
Change an Ecobee preset, but only if it isn't already set to that. And, set a
10 minute timer after any (actual) change.
mode: parallel
icon: mdi:tune-variant
max: 3
trace:
stored_traces: 20
fields:
ecobee:
name: Ecobee thermostat
description: Ecobee thermostat to change
required: true
selector:
device:
manufacturer: ecobee
entity:
domain: climate
preset:
name: Target climate preset
description: Put the ecobee in this mode...
required: true
selector:
select:
options:
- Home
- Away
- Sleep
- Work Sit
- Work Walk
- TV
sequence:
- if:
- condition: template
value_template: "{{ state_attr(\"climate.top_floor\",\"preset_mode\") == preset }}"
then:
- stop: Already in this preset mode.
- service: climate.set_preset_mode
preset_mode: "{{ preset }}"
device_id: "{{ ecobee }}"
- service: timer.start
duration: "600"
entity_id: timer.timer_minimum_heat_change
I would also like to dynamically populate field option selectors for scripts
I have a script that is executed when my template select changes.
It gets its value passed to it from the UI via an entity card (mushroom in this case) which populates the dropdown using a “template select”
- type: custom:mushroom-select-card
entity: select.room_settings_select_room
# select.room_settings_select_room
- select:
- unique_id: room_settings_select_room
optimistic: true
state: >-
{%- from "room_motion.jinja" import get_real_rooms_names -%}
{{ get_real_rooms_names().split(',')
| map('area_name')
| list
| sort
| first
options: >
{{ get_real_rooms_names().split(',') }}
# Action that happens when an option is selected in the dropdown
select_option:
- variables:
room_area_id: >
{{ area_id(option) }}
- service: script.room_settings_dict_load_item
room_area_id: "{{ room_area_id }}"
Once in a while I was to call the script manually… I have added fields to the script. However, because I cannot dynamically populate a curated list of areas into the selector for the field ‘room_area_id’, the , the only choice I have to is show all areas to the user, or to hardcode in the list of rooms generated by my macro. I want to use the macro because its return value may change over time
script:
room_settings_dict_load_item:
alias: room_settings_dict_load_item
mode: single
fields:
room_area_id:
description: The room_area_id of an area
example: 'room_area_id: bathroom'
required: true
# I want to dynamically generate the options in this selector
# so I do not have to maintain them anywhere except in the
# macro 'get_real_rooms_names()'
# I want selector: to accept select.room_settings_select_room as a valid value for the *selector:* key
selector:
# Or I want area: to accept select.room_settings_select_room, or a template as a valid value for the *area:* key
area:
variables:
room: "{{room_area_id}}"
room_settings_storage_id: sensor.room_settings_storage
room_settings: >-
{%- from "room_motion.jinja" import room_settings_dict_load_item -%}
{{ room_settings_dict_load_item(room_area_id) | from_json }}
