tell me pliz design, how I can select those sensors, the specified attribute of which (its value) corresponds to the condition. In my case, the attribute value is in integer.
I tried this:
{% set count = states | selectattr("attribute.quality", 'gt', '10') %}
Assuming quality contains an integer or float value, remove the quotes from '10' (and itâs attributes.quality not attribute.quality). However, the template is fundamentally flawed because it examines all entities and will fail when it encounters the first entity that doesnât have a quality attribute.
UndefinedError: âmappingproxy objectâ has no attribute âqualityâ
You have to include a filter to select the entities that have a quality attribute.
{% set count = states | selectattr('attributes.quality', 'defined') | selectattr('attributes.quality', 'gt', 10) | list | count }}
In addition, if you know that only some sensor entities have the quality attribute, replace states with states.sensor to make the template a bit more efficient.
Hi, thank you for yours reply. To be exact I have ~ 30 sensors of stock.
And these sensors have the âprofitLossPercentageâ (in integer value) attribute. I tried the following kind of code, which shows nothing
{% set count = states.sensor | selectattr('attributes.profitLossPercentage', 'defined') | selectattr('attributes.profitLossPercentage', 'gt', 10) | list | count %}
template only says: Result type: string
This template tracks the following state change events: Domain: sensor
You should know that itâs the custom of this community to assign the Solution tag to the first post, or most complete post, that identifies and resolves the stated problem.
In this case, you marked your own post as the Solution yet all you did was use what I had already suggested (minus the explanation). Thatâs not how the Solution tag is normally used.
