My automation causes an infinite loop in some cases if “mode: queued”.
In case of “mode: single” this does not happen.
There are 3 weather sensors for 3 different providers:
weather.home_met
weather.home_openweathermap
weather.home_gismeteo
I have a Weather card on Lovelace showing a weather from some of those sensors.
To select a weather sensor I use an input_select with 3 options:
input_select:
weather_provider:
options:
- "Met"
- "OpenWeatherMap"
- "Gismeteo"
icon: mdi:weather-pouring
If “Met” is selected then the Weather card uses “weather.home_met” sensor and so on.
Initially I decided to use 3 providers because sometimes some sensors are “unknown” or “unavailable”.
So, if I observe an absence of data on the Weather card, I usually switch to another sensor.
Once I decided to automate this selection using this algorithm:
- If the selected weather sensor becomes “
unknown” or “unavailable” - then try to select another sensor (service: input_select.select_next). - If the next selected weather sensor is also “
unknown” or “unavailable” - then try to select another sensor - until the first initial sensor is selected (means “all sensors are not working”). - If some not-selected weather sensor becomes working - then select this sensor.
- The same steps Nos 1-2 are to be executed in case of manually selecting an option in the
input_selectfield.
Here is the code:
automation:
- alias: "weather: Select available provider"
description: ''
mode: single
variables:
USER_SELECTED_PROVIDER: '{{ states("input_select.weather_provider") | lower }}'
- platform: state
entity_id: input_select.weather_provider
- platform: state
entity_id: weather.home_met
# from: &ref_from_to
# - "unknown"
# - "unavailable"
# to: *ref_from_to
- platform: state
entity_id: weather.home_openweathermap
# from: *ref_from_to
# to: *ref_from_to
- platform: state
entity_id: weather.home_gismeteo
# to: *ref_from_to
condition:
- condition: template
value_template: >-
{% set WEATHER_SENSOR = "weather.home_" + USER_SELECTED_PROVIDER -%}
{{ states(WEATHER_SENSOR) in ['unavailable','unknown'] or
trigger.from_state.state in ['unavailable','unknown'] or
trigger.to_state.state in ['unavailable','unknown'] }}
- repeat:
while:
value_template: >-
{% set PROVIDER = states("input_select.weather_provider") | lower -%}
{%- set WEATHER_SENSOR = "weather.home_" + PROVIDER -%}
{{ states(WEATHER_SENSOR) in ['unavailable','unknown'] and repeat.index <= 3 }}
sequence:
- service: input_select.select_next
- delay:
milliseconds: 100
- service: notify.telegram_chat_weather
message: |-
weather: default provider changed:
{{ USER_SELECTED_PROVIDER }} -> {{ states("input_select.weather_provider") | lower }}
Note that “for:” & “to:” options are commented since the same is achieved by the templated conditions.
Also, the “delay:” was added just in case - and may I remove it?
So, the automation seems to work smooth:
- If I manually try to select a non-working sensor - it will be replaced with the 1st working sensor - or it will stay if all sensors are not working.
- If the selected sensor becomes not-working - it will be replaced with the 1st working sensor - or it will stay if all sensors are not working.
But I am not sure that I should use the “mode: single” option. May be it should be “queued”?
If the last case I observe an infinite loop in this scenario:
- All three sensors are working, the 1st sensor is selected.
- The selected sensor becomes “
unknown” - then the 2nd sensor is selected. - The selected sensor becomes “
unknown” - then the 3rd sensor is selected. - The selected sensor becomes “
unknown” - then the 3rd sensor is still selected. - The 1st sensor becomes working - then I see an infinite loop instead of selecting the 1st sensor.
My questions are:
- The question about the “
delay:”. - Should I stay with the “
mode: single” option? - What could cause the infinity loop?
