Selectable time as Automation trigger
Hi all,
I´m having trouble creating this automation. What I want is to run this automation only when it´s Wednesday and adjusting manually the hour from the frontend. This is the script I have rn:
- id: '1621967683697'
  alias: Check hour and day
  description: ''
  - platform: time_pattern
    minutes: '1'
  condition:
  - condition: template
    value_template: ' ''{{ (now().strftime("%a") == "Wed") and (now().strftime("%H:%M") == states.input_datetime.hour_wed.state)}}'' '
  - service: switch.turn_on
      entity_id: switch.relay_1
  mode: single
Even it seems fine to me the automation won´t trigger.
Any clue?
The quotes (’ ‘’) in your template seems to be wrong. Also the input_datetime should be something like “19:20:00” with seconds.
Something like that could work. You can also check the template in the developer tools to make sure everything is correct.
condition:
    value_template: "{{ (now().strftime('%a') == 'Wed') and (now().strftime('%H:%M:00') == states('input_datetime.hour_wed') ) }}"
You could also use the template as a trigger for the automation. There is no need to check every minute if the automation can trigger.
When you only want to change the hour you chould use a input_number instead the the input_datetime
@maverick-66 Your trigger and condition can be as simple as this:
  - platform: time
    at: input_datetime.hour_wed
condition:
  - condition: time
    weekday:
      - wed
Checking every minute is very rarely the right way to set up a trigger.
