First of all, I am using HA Core 2024.7.3 on Python 3.12.4 in a clean venv on Rocky Linux 9
I have a Honeywell Total Connect Comfort (EU) system running and use the build-in integration.
When I look up any of the climate entities in STATES tab on the Developers tools page (for instance climate.eetkamer
), it shows me this list of attributes:
hvac_modes: off, heat
min_temp: 5
max_temp: 35
preset_modes: none, temporary, permanent
current_temperature: 22.6
temperature: 11
preset_mode: permanent
status:
setpoints:
this_sp_from: '2024-07-19T22:30:00+02:00'
this_sp_temp: 16
next_sp_from: '2024-07-20T08:00:00+02:00'
next_sp_temp: 21
zone_id: '*******'
active_faults:
- faultType: TempZoneActuatorLowBattery
since: '2024-07-16T17:57:07'
setpoint_status:
target_heat_temperature: 11
setpoint_mode: PermanentOverride
temperature_status:
temperature: 22.5
is_available: true
friendly_name: Eetkamer
supported_features: 401
Now, when I go to the TEMPLATE tab and enter the following:
{{ states.climate | selectattr('attributes.friendly_name','eq','Eetkamer') | selectattr('attributes.temperature','defined') | list }}
it returns the climate entity as expected (manually formatted for readability):
[<template TemplateState(<state climate.eetkamer=off;
hvac_modes=[
<HVACMode.OFF: 'off'>,
<HVACMode.HEAT: 'heat'>
min_temp=5.0,
max_temp=35.0,
preset_modes=[
'none',
'temporary',
'permanent'
current_temperature=22.6,
temperature=11.0,
preset_mode=permanent,
status=
setpoints=
this_sp_from=2024-07-19T22:30:00+02:00,
this_sp_temp=16.0,
next_sp_from=2024-07-20T08:00:00+02:00,
next_sp_temp=21.0,
zone_id=*******,
active_faults=[
'faultType': 'TempZoneActuatorLowBattery',
'since': '2024-07-16T17:57:07'
setpoint_status=
target_heat_temperature=11.0,
setpoint_mode=PermanentOverride,
temperature_status=
temperature=22.5,
is_available=True,
friendly_name=Eetkamer,
supported_features=401
@ 2024-07-19T20:37:53.646918+02:00>)
Now, instead of making sure temperature is defined, I want to select all the climate entities that have the attribute active_faults defined. However, the following template returns an empty list:
{{ states.climate | selectattr('attributes.friendly_name','eq','Eetkamer') | selectattr('attributes.active_faults','defined') | list }}
Specifying ANY other attribute returns correct data, (preset_modes
works fine and even status.setpoints.this_sp_from
returns the same data). Only when I specify active_faults
it returns an empty list.
Similar for state_attr:
{{ state_attr(' climate.eetkamer','temperature') }}
Returns the expected value (11.0
in this example) but
{{ state_attr('climate.eetkamer','active_faults') }}
returns null
Can anybody help me out here? I need to create some sensors based on the active_faults attribute.
Thanx for your help!
